idle problem...again!
Alright, im havin some idle problems again. Tonight i was just drivin around, pushin my car alil and i missed a gear. When i got home i noticed my idle didn't drop past 1300 - 1400.
I rev'd it up and it went down to 1000 and bounced back up to 1400. I checked for any vac line leakes or maybe something got disconnected, nothin.
I was wonderin if me missing a gear could **** something up with my idle, stupid question but i'm just wonderin.
What else could the problem be?
Check your throttle body or cable to see if it's sticking a little. Also check the TPS sensor. It is very breakage prone(even when the motor is in the car).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jigga008_99 »</TD></TR><TR><TD CLASS="quote">Check your throttle body or cable to see if it's sticking a little. Also check the TPS sensor. It is very breakage prone(even when the motor is in the car).</TD></TR></TABLE>
what do u mean sticking, and what am i checking the tps for.
i changed my iacv alittle while ago so i don't know what the problem could be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicNA »</TD></TR><TR><TD CLASS="quote">when you say missed you didnt go from like 3rd to 2nd or anything did you?</TD></TR></TABLE>
no, i missed 2nd to 3rd...haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 »</TD></TR><TR><TD CLASS="quote">what did the problem end up being??</TD></TR></TABLE>
i have no clue, but i went back to my car to try and work on it, i turn the car on, and it's purring at 900 rpm, idk, i'm still scratchin my head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff »</TD></TR><TR><TD CLASS="quote">the honda gods have smiled upon you.......... hopefully the will smile upon my code 63</TD></TR></TABLE>
yeah seriously, not often that happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicstoo(s)low »</TD></TR><TR><TD CLASS="quote">Thank you for spelling "idle" correctly. It's about damn time someone did. That's all.
"y0 fellaz mah idol is fucked uppp"
haha
</TD></TR></TABLE>"y0 fellaz mah idol is fucked uppp"
haha
