injector cleaner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frito1 »</TD></TR><TR><TD CLASS="quote">Chevron fuel injector cleaner with every oil change
Make sure you use their Techron Concentrate and not their Fuel Injector cleaner. I've used the Techron Concentrate and found it to be a good product.
Another product you may want to look at is Schaeffers Neutra 131. I've just switched to this product because I can by it by the gallon and its cheaper than the Techron Concentrate.
</TD></TR></TABLE>Make sure you use their Techron Concentrate and not their Fuel Injector cleaner. I've used the Techron Concentrate and found it to be a good product.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 »</TD></TR><TR><TD CLASS="quote">bg44k its 20$ at napa but works great.</TD></TR></TABLE>
BG 44k is a good product and is a very strong cleaner. With that said, you shouldn't use BG 44k more than twice a year and it is recommended that you change your oil fairly soon after running the product.
I prefer Neutra 131 because it cheaper ($13/gal) and can be used in maintenance dosages. It also provides upper cylinder lubrication that other products don't offer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 »</TD></TR><TR><TD CLASS="quote">why do you have to change oil afterwards? i changed my oil and put 44k in like 200 miles later. its bin 1k since should i change it now?</TD></TR></TABLE>
The reason people recommend changing the oil after use is because BG44K is a strong cleaner. As a result there may be a lot of carbon and other deposits that could end up in the oil. The recommended interval for use with BG44k is roughly every 10-15K miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote">
The reason people recommend changing the oil after use is because BG44K is a strong cleaner. As a result there may be a lot of carbon and other deposits that could end up in the oil. The recommended interval for use with BG44k is roughly every 10-15K miles.</TD></TR></TABLE>
dam, i also did the sea foam treatment a few days after bg44k. i guess i should change my oil early
wiZCo
Feb 13, 2007 12:52 PM
