injector cleaner
Old Oct 23, 2003 | 01:11 PM
THE94GSR's Avatar
Default injector cleaner
which is the best way and product to clean your injectors
Old Oct 23, 2003 | 01:19 PM
Frito1's Avatar
Default Re: injector cleaner (THE94GSR)
Chevron fuel injector cleaner with every oil change
Old Oct 23, 2003 | 01:23 PM
timmy8151's Avatar
Default Re: injector cleaner (Frito1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frito1 &raquo;</TD></TR><TR><TD CLASS="quote">Chevron fuel injector cleaner with every oil change </TD></TR></TABLE>
Make sure you use their Techron Concentrate and not their Fuel Injector cleaner. I've used the Techron Concentrate and found it to be a good product.
Another product you may want to look at is Schaeffers Neutra 131. I've just switched to this product because I can by it by the gallon and its cheaper than the Techron Concentrate.
Old Oct 23, 2003 | 03:16 PM
oMek's Avatar
Default Re: injector cleaner (timmy8151)
bg44k its 20$ at napa but works great.
Old Oct 23, 2003 | 03:35 PM
Calavera's Avatar
Default Re: injector cleaner (oMekoneDC2)
How about the STR(sp?) one?
Old Oct 23, 2003 | 03:49 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">bg44k its 20$ at napa but works great.</TD></TR></TABLE>
BG 44k is a good product and is a very strong cleaner. With that said, you shouldn't use BG 44k more than twice a year and it is recommended that you change your oil fairly soon after running the product.
I prefer Neutra 131 because it cheaper ($13/gal) and can be used in maintenance dosages. It also provides upper cylinder lubrication that other products don't offer.
Old Oct 23, 2003 | 03:53 PM
oMek's Avatar
why do you have to change oil afterwards? i changed my oil and put 44k in like 200 miles later. its bin 1k since should i change it now?
Old Oct 23, 2003 | 04:04 PM
mickey513's Avatar
Chevron Fuel System cleaner once a year.
Old Oct 23, 2003 | 04:05 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">why do you have to change oil afterwards? i changed my oil and put 44k in like 200 miles later. its bin 1k since should i change it now?</TD></TR></TABLE>
The reason people recommend changing the oil after use is because BG44K is a strong cleaner. As a result there may be a lot of carbon and other deposits that could end up in the oil. The recommended interval for use with BG44k is roughly every 10-15K miles.
Old Oct 23, 2003 | 04:23 PM
oMek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
The reason people recommend changing the oil after use is because BG44K is a strong cleaner. As a result there may be a lot of carbon and other deposits that could end up in the oil. The recommended interval for use with BG44k is roughly every 10-15K miles.</TD></TR></TABLE>
dam, i also did the sea foam treatment a few days after bg44k. i guess i should change my oil early
clayhill797
Apr 21, 2008 04:34 AM
tegda
Aug 8, 2007 12:47 PM
wiZCo
Feb 13, 2007 12:52 PM
oakpwr
Nov 11, 2006 07:03 AM
EF_ST@TUS
Aug 12, 2005 07:03 AM
