LS with b16 tranny
I have read some on this and am thinking of getting a b16 5 speed for my stock LS teg, i might turbo in the future, so would this hurt? how bad does it rev duiring hwy driving? any info appreciated. Also, how noticable are the acceleration gains? thanks in advane
Hey- I'm using a B16 tranny with my Ls/Vtec setup. Using the shorter gearing of a B16 tranny with my setup has been awesome. Acceleration is greatly improved...feels like I added tons of horsepower. The gears are really quite short and are comparable (if not the same) as a Type R tranny. Driving on the freeway, however, I do run at around 4k-4250rpm while travelling at 80mph. It sounds like my engine is working harder, but if a Type R can handle it, I think my Ls/Vtec or your LS setup can as well. The only thing you may want to upgrade is the differential. The stock B16 diff is pretty weak, and switching to an diff will strengthen everything.
If you ARE going turbo, you may want to stay with your LS tranny. The longer gears combined with the turbo power will work well. Going N/A, you want quick revs to get higher in the powerband. Going turbo you want to somewhat draw out your revs and take full advantage of your power. Just food for thought. Hope it helps.
What you said is primarily true, but the LS tranny + boost thing is a myth. Shorter gearing is always better for acceleration. Always. It doesn't matter if you're NA or FI.
I haven't upgraded my differential yet, but I may switch to a Quafe (i believe that's how you spell it) differential. They're strong 's that are widely used with performance Honda's/Acura's. As for the entire "using LS tranny when you turbo"...I really don't know if it works better. All I do know though, is that an aquaintance of mine was interested in using my LS tranny with his turbo'd GSR motor in his '95 Civic instead of te GSR tranny he had. Any truth to the question of whether or not to use longer hears when you turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraholic »</TD></TR><TR><TD CLASS="quote">What you said is primarily true, but the LS tranny + boost thing is a myth. Shorter gearing is always better for acceleration. Always. It doesn't matter if you're NA or FI.</TD></TR></TABLE>
julio_bOostamante
24
Jan 5, 2006 04:53 PM
Ratchback
Dec 23, 2005 07:42 AM
BoostedDelsol
13
Jan 22, 2005 01:37 PM
