selecting aftermarket brakes?
Old Oct 23, 2003 | 10:07 AM
tweekerz's Avatar
Default selecting aftermarket brakes?
My brakes are stock on my 01 GSR. I have VGX pads on right now. Looking to track and autocross more and my little brakes don't cut it. Need help increasing my braking power. Any suggestions would help. Would replacing the rotor with cross drilled or slotted help? Is an ITR brake conversion worth it?
TIA
Old Oct 23, 2003 | 10:21 AM
Bill Hook's Avatar
Default Re: selecting aftermarket brakes? (GoodTimes)
Buy better tires. X-drilled won't help, slotted might, but only a little.
I know nothing about your pads, but they're probably better than OEM.
ITR brake conversion will only firm up pedal feel and reduce fade potential.
Old Oct 23, 2003 | 10:27 AM
acuraholic's Avatar
Default Re: selecting aftermarket brakes? (Bill Hook)
I agree. Buy some quality blanks, Axxis Ultimates (or equivalent), maybe some stainless lines, and some good fluid and call it a day.
Old Oct 23, 2003 | 10:30 AM
THE94GSR's Avatar
Default Re: selecting aftermarket brakes? (acuraholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraholic &raquo;</TD></TR><TR><TD CLASS="quote">I agree. Buy some quality blanks, Axxis Ultimates (or equivalent), maybe some stainless lines, and some good fluid and call it a day. </TD></TR></TABLE>
get some cobalt
Old Oct 23, 2003 | 10:35 AM
tweekerz's Avatar
Thanks for the reply guys. I currently have 205/45/16' Khumo Ecstas on my Slipsteams right now w/ half tread life left. Maybe going to go Azenis next. The pads I have on right now are the Qualitee VGX pads to clear things up. How will steal braded lines help?
Old Oct 23, 2003 | 10:49 AM
acuraholic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoodTimes &raquo;</TD></TR><TR><TD CLASS="quote">How will steal braded lines help?</TD></TR></TABLE>
Just a more solid and consistent pedal feel. They won't shorten distances or anything.
Old Oct 23, 2003 | 11:07 AM
Bill Hook's Avatar
Just a more solid and consistent pedal feel. They won't shorten distances or anything.</TD></TR></TABLE>
Allegedly, the brake reaction time is faster, which equals a few feet shorter stops.
Braided lines can trap dirt between inner hose and braid causing abrasion and failure, so don't unless you are under the car 3-4 times a year (probably takes a couple years to wear enough to fail) to check. A MC brace would be a better mod to improve feel some.
Old Oct 23, 2003 | 11:16 AM
tweekerz's Avatar
Sorry I am new at this, MC Brace is ? Master Cyclinder something.... Where can I get this and how much do they run for?
Old Oct 23, 2003 | 11:21 AM
acuraholic's Avatar
Right. It's a Master Cylinder brace. There's some good info in this thread if you're interested...
https://honda-tech.com/zerothread?id=556902
Old Oct 23, 2003 | 12:44 PM
Bill Hook's Avatar
I wouldn't let that thread scare me too much, but tweakmeister's brace is good enough and not so rigid that it'll tear out your front tower.
Old Oct 23, 2003 | 03:12 PM
n0 iNTegRiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoodTimes &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply guys. I currently have 205/45/16' Khumo Ecstas on my Slipsteams right now w/ half tread life left. Maybe going to go Azenis next. The pads I have on right now are the Qualitee VGX pads to clear things up. How will steal braded lines help?
A wider wheel and tire setup would help with grip, too, if you can afford it.
OUT OF ORDER ROB
Feb 21, 2008 10:12 PM
joenationwide
20
Aug 17, 2004 07:37 PM
Eg6_RcR
Aug 9, 2003 06:11 AM
CRX A4
58
Nov 18, 2002 06:27 PM
onyx00
Jul 3, 2001 09:31 AM
