axle nut threading?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si »</TD></TR><TR><TD CLASS="quote">use a breaker bar to bust it loose, Makes things 100Xs easier</TD></TR></TABLE>
Impact gun wouldnt hurt either, but I'm usually too lazy to get mine out so I just use the breaker bar method....
I just dominated that nut right now! i got that nut off in 20 seconds using a 18 in breaker bar with a 4 foot pipe extension. it was soooooo easy. didnt even use PB or wd-40. it suprised me cause everyone makes such a big deal about it. anyway, yeah!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Another thing to remember is to try to loosten the nut, not the bolt.</TD></TR></TABLE>
word, my axle has a nut on it too, not a bolt
what do you all use to make that dip in the new axle nut? when i tried getting the dip back up to take off the nut, i used a flat head screw driver and it went tore thru the nut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 »</TD></TR><TR><TD CLASS="quote">what do you all use to make that dip in the new axle nut? when i tried getting the dip back up to take off the nut, i used a flat head screw driver and it went tore thru the nut.</TD></TR></TABLE>
ur doing right, just rip it up, tore it apart, out damn dip... they're made to do just that - all remans/new axles come with new nuts. Honda says not to but if you reuse it, just make sure the new dip is in a different place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 »</TD></TR><TR><TD CLASS="quote">but what tool do you use to stake the nut down? not taking out the dip but making one on a new nut. what tools? screwdrivers go thru the metal.</TD></TR></TABLE>
I use a big crappy screwdriver. you don't have to beat it flat into the notch, just put that little dip back in it so that the nut won't back off.
