Eagle rods or Probe rods?? please help
Old Oct 22, 2003 | 03:54 PM
JunIntegra's Avatar
Default Eagle rods or Probe rods?? please help
if you personally have had problems or any positive experiences with either of these rods please state so. probes come with 9mm bolts and eagle with 8mm. probe are also lighter.
im building my b18c1 in january so i need to start buying parts. please help
Old Oct 22, 2003 | 03:57 PM
bryan305's Avatar
Default Re: Eagle rods or Probe rods?? please help (JunIntegra)
never heard of probes....
Old Oct 22, 2003 | 04:25 PM
JunIntegra's Avatar
Default Re: Eagle rods or Probe rods?? please help (bryan305)
Importbuilders.com sells them. supposed to be 15% lighter than eagle.
im doing an NA setup w/ IB spec Wiseco's for around 12:1 compression. im sure plenty of you here on this forum kno about them, ...anyone>?
Old Oct 22, 2003 | 04:33 PM
johnzm's Avatar
probes are good. personally i hate eagle, just becasue alot of people see them as a all in one rod. probes, on the other hand, are more or less designed to run in allmotor apps, thats whyt hey are 15% lighter and are only capable of handling ithink ~350HP
Old Oct 22, 2003 | 06:12 PM
b19coupe's Avatar
I had Eagle rods in my motor for a while with no problems, but the size of the rod bolts had me nervous anywhere past 9,000 rpm. I got the Probes and the rod bolts were 1mm thicker, which I liked. I ended up going back to my Crowers for other reasons -easier to rebuild a motor and do the swap later, rather than pulling the motor and rebuilding it at the same time.
Old Oct 22, 2003 | 10:44 PM
ArinX's Avatar
probes are going into my build.
Old Oct 22, 2003 | 11:27 PM
speedyonez's Avatar
What size rod bolts do crowers have thats what i am running..
Old Oct 22, 2003 | 11:41 PM
b19coupe's Avatar
Default Re: (speedyonez)
I believe that the Crower rod bolts are 3/8". They are bigger than the Probe rod bolts by a little.
Old Oct 22, 2003 | 11:51 PM
speedyonez's Avatar
No ****?... damn now i wont fell so bad about 10k =o)
Old Oct 28, 2003 | 06:44 PM
TodaSi's Avatar
I haven't found Probe rods for a GS-R, do they even make them? What is the weight of the rods in grams?
Old Oct 28, 2003 | 06:46 PM
six sigma racing's Avatar
Default Re: (TodaSi)
for a little more.. i would ditch out for a the crower econo billets.. just my opinion
Old Oct 28, 2003 | 06:47 PM
b19coupe's Avatar
They do make Probe rods for a GSR-I had a set. Got them from Jeff.
Old Oct 28, 2003 | 08:47 PM
evilxkid's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">They do make Probe rods for a GSR-I had a set. Got them from Jeff.</TD></TR></TABLE>
did your's require ls berings. i got probe rods for a gsr and the gsr berings are too small.
Old Oct 29, 2003 | 12:47 AM
jeremy.'s Avatar
bump
Old Oct 29, 2003 | 01:12 AM
CRXEE8's Avatar
Default Re: (ek_jeremy)
I'm using Probes with IB Spec 11.8:1 Wiseco's in my B20VTEC. I'm very happy with this setup and the quaility of the Probe's is great. I'm running on stock sleeves bored out to 85 mm. and has 1500 miles on it. Not problem so far
For NA buy Probe and use Eagle for FI.
haters909
Jun 10, 2012 10:01 PM
reaction360
Sep 22, 2007 05:52 PM
Hoosier Daddy
Oct 28, 2003 07:18 AM
GOLDBERG
Oct 12, 2003 09:52 AM
blykins
May 29, 2003 04:57 AM
