brakes
ive got a squealing brake problem and im sure it is pads. i want to replace the rotor with a slotted or drilled, but im not sure what to go with. any suggestions? thanks-andy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 »</TD></TR><TR><TD CLASS="quote">"always function before fashion" -me</TD></TR></TABLE>
Search for the Autozone + Rotor threads ....
https://honda-tech.com/zerothread?id=655608
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 »</TD></TR><TR><TD CLASS="quote">what about the cobalts?</TD></TR></TABLE>
Call and talk to Andie and he'll help you out per your needs and application(s).
Other than that The Axxis Ultimates work nicely as an improvement over stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArmyGreen EG »</TD></TR><TR><TD CLASS="quote">im sportin the autozone rotors on my 97 never had any problems</TD></TR></TABLE>
what pads?
what pads?
Cobalt GT-Sport pads are probably what you'd want. They're the best daily-driver type pad Cobalt currently sells -- awesome stopping power. If you're concerned about squeeling, though, you may want to consider something else. The ones I've used have squeeled like crazy. I didn't use shims, though, so that might make a difference.
Cobalt's website is http://www.cobaltfriction.com, and their phone # is 877-562-9237. They're down here in Fort Lauderdale, so you should be able to get stuff pretty quick. And be sure to mention you're from Honda-Tech so you get the discount.
Autozone rotors will do just fine, and they're cheap, too. The ones I got for the LS were like $22 a piece, and I think the Type R ones run around $29.
what pads?</TD></TR></TABLE>
stock but they are just about done with,im probly going to switch to axxis ultimate my old roomate had them on his hatchcrap w\ITR brakes he never had anything bad to say about them.
hatchinprogress
Aug 31, 2006 10:01 PM
