sqweaking noise from upper strut bushing???????
Old Oct 22, 2003 | 11:36 AM
nortel's Avatar
Default sqweaking noise from upper strut bushing???????
how the hell do i get the sqweak to go away, it is loud as fawk.........i didnt know it could sqweak this loud......#7
Old Oct 22, 2003 | 11:48 AM
phantom_sol's Avatar
Default Re: sqweaking noise from upper strut bushing??????? (nortel)
i greased everything everywhere but i think finally, its my camber kits. but thats with me...not sure if that helped you out much.
ingalls = noise after a few months
Old Oct 22, 2003 | 12:23 PM
pdiggitydogg's Avatar
white lithium grease
spray form is nice...but not necessary
Old Oct 22, 2003 | 01:58 PM
nortel's Avatar
Default Re: (pdiggitydogg)
ok ill try the grease when i get home
Old Oct 22, 2003 | 02:00 PM
GimpyAccord's Avatar
Default Re: (nortel)
I put wireloom (black split loom like you use on stereo install) around the tops and bottoms of every spring job I do and grease it.
has worked like a charm for years!
Old Nov 1, 2003 | 12:44 PM
michaelpr's Avatar
New User
Default Re: (GimpyAccord)
How do you know it is the bushing and not the strut itself?
Old Nov 1, 2003 | 01:31 PM
Discosteak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">white lithium grease
spray form is nice...but not necessary</TD></TR></TABLE>
werd
Old Nov 1, 2003 | 03:25 PM
Default Re: (BADEG6)
i just sprayed mine with white lithium grease. no more squeeks. definately worth the 3 bux.
just stuch the hose into each end of the camber kit. lowered a little, sprayed more. then dropped the car.... jacked it all the way up again and no more squeeks.
Old Nov 1, 2003 | 07:40 PM
michaelpr's Avatar
New User
Default Re: (phantom_sol)
How long did you have the struts before the the squeak?
Did the sqeak just appear, or did you do some other front-end changes or alignment?
Could a squeak come from inside the strut itself?? I have new struts (stock replacements) and I now have a squeak just after an alignment.
Old Nov 1, 2003 | 11:37 PM
JforJonathan's Avatar
Default Re: (michaelpr)
what are you supposed to spray the white litheum grease on?
Old Nov 2, 2003 | 02:46 AM
Formula 1's Avatar
Default Re: (Dj Villain)
i hate squeaks ...
coilover sleeves
full body coilover system
Tein
colton1808
Feb 28, 2018 01:24 PM
greenwar
Apr 26, 2008 06:11 PM
TOO MUCH TORQUE
Suspension & Brakes
Apr 23, 2008 06:51 AM
mxl360
Aug 19, 2007 04:57 PM
ArchAngel Sabastian
Feb 5, 2002 11:51 AM
