sqweaking noise from upper strut bushing???????
Re: sqweaking noise from upper strut bushing??????? (nortel)
i greased everything everywhere but i think finally, its my camber kits. but thats with me...not sure if that helped you out much.
ingalls = noise after a few months
Re: (nortel)
I put wireloom (black split loom like you use on stereo install) around the tops and bottoms of every spring job I do and grease it.
has worked like a charm for years!
Re: (BADEG6)
i just sprayed mine with white lithium grease. no more squeeks. definately worth the 3 bux.
just stuch the hose into each end of the camber kit. lowered a little, sprayed more. then dropped the car.... jacked it all the way up again and no more squeeks.
Re: (phantom_sol)
How long did you have the struts before the the squeak?
Did the sqeak just appear, or did you do some other front-end changes or alignment?
Could a squeak come from inside the strut itself?? I have new struts (stock replacements) and I now have a squeak just after an alignment.
greenwar
04-26-2008 06:11 PM
