12 second Honda
Old Sep 3, 2001 | 07:09 PM
RB's Avatar
RB
New User
Default 12 second Honda
Okay, the lads over in the Integra forum had a good laugh at my last post, conceived in ignorance I'll admit. Couldn't stop laughing myself when I read the responses. But this is important. Take an affordable Honda/Acura (not a 24valve NSX) that has a 6 or 4 cyl. vtec engine and make it do a 12 second quarter mile, NO nitrous. How much would the modifications cost? What parts would be required?
I am not a Honda expert, but then I'm not pretending to be. I'm looking for an affordable ($3000), streetable Honda combo that can run with an LS1 Vette in the 1/4. Tell me, can it be done?
Old Sep 3, 2001 | 07:59 PM
rioninja's Avatar
Default Re: 12 second Honda (RB)
I'm no expert, but most people suggest a boosted B18b. That engine in a lighter civic should get you close to that. Then again, the turbo would run you about 3k alone for a good setup...
Old Sep 3, 2001 | 08:07 PM
JinMTVT's Avatar
New User
Default Re: 12 second Honda (RioNinja)
with 3k it's pretty muhc impossible
u have 2 choice though..
going easy way with turbo setup ..in a small car like EF civic or CRX
or H22a stroked to 2.5l...worked engine in the same car..
or in an insight ahha but that would cost u more than 3K by a lot
ahah
so if u only have 3K$ to get a 12sec car ... just rethink of it longly..or forget ur dream
but either way 12sec is not and easy time to get..
NSX Type S ZERO ( JDM 280hp) is supposed to do 13sec flush
again ..
mmm
CRX with an NSX engine in the back
seen that on a pic recently ..
that would be mid 12 i guess..
maybe low 12 hehe
Old Sep 3, 2001 | 08:38 PM
CRX_VTEC's Avatar
Another guys quest for 12 sec land huh? Well..... we are all allowed to dream. And the cost of this dream is for 3K or less.. HAHHAHA.. thats pretty funny. How many people here run 12's?? Its not easy.... alot harder then what 3K will get you. If 3k is all i took to get 12's.... half of the Honda Tech members will be 12 or faster. Unless your a EF or EG chasis dont even think about it. Turbo is the ONLY chance you have for what will get you 12's and thats with about 3K in engine mods NOT included into the turbo cost. Like I said... unless your EF or EK its not possible. Well... you could always rent a F50 ... thats less then 3,000 isnt it??!
Old Sep 4, 2001 | 06:46 AM
bigTom's Avatar
turbo + pistons/rods... that would be the cheapest possible way imo... and the easiest... more than 3g's though
Old Sep 4, 2001 | 06:52 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: 12 second Honda (ek9t)
N/A = $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Turbo = Fast.
Old Sep 4, 2001 | 07:08 AM
Seraph0's Avatar
Well I spent $3K and I am knocking on 12's. Would be there if I drove better. But that $3K was on top of my $20K car..... doh..
If you are serious, check out the Forced Induction forum. That is where you will get the most help.
Old Sep 4, 2001 | 08:28 AM
fsp31's Avatar
Default Re: 12 second Honda (MarkC)
Another thing that nobody seems to consider on a car like this is power delivery and suspension. It will cost you at least 2 grand just to get that power to the ground reasonably. A 350 HP monster motor tossed into mom's old Civic is not going to produce impressive times. Impressive one-wheel burnouts maybe...
Old Sep 4, 2001 | 09:25 AM
TheShad0w's Avatar
Default Re: 12 second Honda (fsp31)
I'd say you could have a dependable fast setup for 7 k
Old Sep 4, 2001 | 10:06 AM
optiontoo's Avatar
New User
You could do an LS/VTEC... mine cost me around $2,200 to do, that was for new stock pistons, ARP bolts on the stock rods, pretty much everything else stock. All I did was machine work and replace all the wear-able bits and it came to $2,200. It was in an Integra (1990), making 200 to the wheel. Never ran it on the drag strip but 12's aren't inconceivable.
Old Sep 4, 2001 | 10:26 AM
BoM's Avatar
BoM
Default Re: 12 second Honda (optiontoo)
buy LIP's gsr hahahah
for a economical setup for 12's i'd have to say this
gsr engine in a civic hatch, inline pro headgasket turbo the beast with a revhard or drag, 10-12 psi and then lighten your car a little, throw in some slicks and your set..
3k + 3k + 1k pretty xppensive...
Old Sep 4, 2001 | 10:59 AM
VTEC4GS's Avatar
if you have a Type R, get these 4 things:
Toda spec A camshafts
Toda 4-2-1 header
GBR programmed ECU/harness adapter
CTR pistons and bottom end rebalance
Sell your stock R cams
do your own labor.
Greg
Old Sep 4, 2001 | 11:12 AM
highmilehatch's Avatar
Default Re: 12 second Honda (vtec4gs)
Hey Greg hows the frog? Any pics or anything?
Old Sep 4, 2001 | 02:45 PM
VTEC4GS's Avatar
Default Re: 12 second Honda (turboeg)
hey, its fine last time I checked ... cheetah is the one thats trying to wreck havoc.
Greg
Zubeyr Dahoo
Feb 12, 2019 05:52 PM
ylw95stang
Feb 20, 2014 03:20 AM
TheMostHated
Feb 15, 2008 05:28 AM
Andrey
Feb 10, 2005 02:34 AM
