HELP! My car is undrivable
Old Oct 22, 2003 | 10:23 AM
Mr. 1582's Avatar
Default HELP! My car is undrivable
My idle was going crazy form 700rpm to 35000rpm no C.E.L. I did a seach and I needed to clean IAC. I clean it then I got a C.E.L. codes 14 (defective IAC or malfuntion in IAC system) for a week and now I'm getting a code 45 (too rich condition). Now it's reving to 4500rpm and it will take a sec or two to stop.
What should I do and how do I clean my IAC correctly ?
Old Oct 22, 2003 | 10:26 AM
SloCivicHMM's Avatar
Default Re: HELP! My car is undrivable (Mr. 1582)
Might need a new one....cleaning can only work so long...
Old Oct 22, 2003 | 10:32 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. 1582 &raquo;</TD></TR><TR><TD CLASS="quote">
What should I do and how do I clean my IAC correctly ? </TD></TR></TABLE>
Use brake or cabeurator cleaner to clean the IACV screens.
Make sure the plug is also connected with it.
Give us more details on motor/ecu and other mods as well.
Old Oct 22, 2003 | 11:00 AM
aw1234dude's Avatar
Default Re: HELP! My car is undrivable (poison)
Did you completely remove the IACV? If you did there was the two coolant lines on the bottom of the sensor which probably drained off. Ive heard of people having erattic idle due to small air bubbles stuck in their coolant lines. You might want to try to bleed out your coolant system.
Old Oct 22, 2003 | 11:06 AM
Mr. 1582's Avatar
Default Re: HELP! My car is undrivable (aw1234dude)
That may be it because the old line were balloned and I replaced them.
I have a D16Y7
Modified by Mr. 1582 at 8:21 AM 10/23/2003
Pure Sol
Jan 3, 2008 01:01 PM
pumpkyn
20
Jul 13, 2006 04:51 PM
Xtian8
Sep 12, 2004 12:37 PM
SiR HatchAlot
Oct 22, 2003 03:52 PM
