88 crx looking to put b18c5 but want to make the car odb2 can it be done?
Old Oct 22, 2003 | 12:25 AM
whitemike1644's Avatar
Default 88 crx looking to put b18c5 but want to make the car odb2 can it be done?
well can i put a b18c5 into my 88 crx hf and keep it odb2 so i can take it to the ref and pass smog? or do i have to make everything odb0 or what how can this work?
Old Oct 22, 2003 | 12:28 AM
Crxer's Avatar
Default Re: 88 crx looking to put b18c5 but want to make the car odb2 can it be done? (whitemike1644)
I think they have a kit to make your car odb0 to odb2. Try doing a search for it.
Old Oct 22, 2003 | 07:41 PM
ttt
Old Oct 23, 2003 | 06:29 AM
redzcstandardhatch's Avatar
something different
why not just obd1?
Old Oct 23, 2003 | 07:11 AM
Jaker's Avatar
You can convert your car to OBD2 using the OBD0 to OBD2 adapter harness. However, if your swap is USDM, you will have to add a 2nd O2 sensor and a fuel tank pressure sensor. If the swap is JDM, its as easy as an OBD1 swap.
Old Oct 23, 2003 | 08:49 PM
StorminMatt's Avatar
Default Re: 88 crx looking to put b18c5 but want to make the car odb2 can it be done? (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">You can convert your car to OBD2 using the OBD0 to OBD2 adapter harness. However, if your swap is USDM, you will have to add a 2nd O2 sensor and a fuel tank pressure sensor. If the swap is JDM, its as easy as an OBD1 swap.</TD></TR></TABLE>
You also have to add a crankshaft speed fluctuation sensor. As for JDM, it is indeed as easy as an OBDI swap, since the JDM ECU is basically just an OBDI ECU with OBDII plugs. But it may not pass a California referee. If this is a problem, you will probably need to wire up the car with the USDM ECU.
Old Oct 23, 2003 | 08:53 PM
Jaker's Avatar
Default Re: 88 crx looking to put b18c5 but want to make the car odb2 can it be done? (StorminMatt)
The Crank Fluctuation Sensor is part of the OBD2 USDM motor, so it does not need to be added. The wiring back to the ECU or adapter will need to be added, but then so will a bunch more wiring.
ser13
Aug 21, 2012 06:02 PM
EG8GSR
Oct 25, 2007 10:50 AM
RiceRocketDave
Jul 24, 2006 06:20 PM
k24a4kid
Jan 24, 2005 10:05 AM
Blackhatch94
Nov 12, 2003 06:10 PM
