b18c into eg.. problem...
Old Oct 21, 2003 | 08:51 PM
wizzards581's Avatar
Default b18c into eg.. problem...
GSR... its started fine.. no check engine... no wiring has been changed... while gas is pressed it stalls.. no gas is given while gas is pushed ... wats the problem?? did i need to change a20 to a17? help me now. thanks.
Old Oct 21, 2003 | 08:56 PM
Filliam H. Muffman's Avatar
Default Re: b18c into eg.. problem... (wizzards581)
im not sure, but the car does that when your map sensor isnt plugged in, maybe thats it?
Old Oct 21, 2003 | 08:58 PM
Default Re: b18c into eg.. problem... (JUN EK9)
weas that located?
Old Oct 21, 2003 | 09:01 PM
tzonni's Avatar
top of the throttle body
Old Oct 21, 2003 | 09:03 PM
Default Re: (tzonni)
its in...
Old Oct 21, 2003 | 10:18 PM
beseman's Avatar
Default Re: (wizzards581)
somethign with the fuel delivery, pump, filter, fpr check em
Old Oct 21, 2003 | 10:25 PM
biassj's Avatar
Default Re: (beseman)
Things I would check:
Throttle cable - see if it's hook up good
Timing - if it's off one tooth this can cause your problem
Old Oct 21, 2003 | 10:29 PM
Team 4's Avatar
Default Re: (biassj)
I think you do have to change the pin locations.
Old Oct 21, 2003 | 10:50 PM
degooser's Avatar
i bet i know what it is....
check your fuel line..did you use the stock d series fuel line???
on the fuel rail on a d series it goes washer, fuel line, washer, cap
on the b series fuel line it should go washer, b series line, washer with holes in it, and then to top it off cap bolt thing with holes in it...
also on the d series fuel rail where the fuel line goes in there is a hole that fuel goes into...if you notice closely that on the b series fuel rail there is no hole..fuel enters the rail via the end of the rail...
anyways hope that helps...
Old Oct 21, 2003 | 10:57 PM
degooser's Avatar
Default Re: b18c into eg.. problem... (degooser)
also if you did use the b series fuel line and what not...
if your car was previoulsy a DX u use the map sensor plug off the firewall not the one on the harness...
Old Oct 22, 2003 | 04:47 AM
mine is si... ???
Old Oct 22, 2003 | 08:23 AM
degooser's Avatar
did you use the b series fuel line?
Old Oct 22, 2003 | 12:51 PM
FallenEGsi's Avatar
could be timing...fuel pump...spark plugs...or clogged injectors
Old Oct 22, 2003 | 04:01 PM
i use everything from gsr... i changed spark plugs... i think timing shouldnt be off.... i dont know about fuel lines... how long did you have to idle the motor after being swaped?
theres a sensor on top of the manifold that broked.. it has the pins still but does not clip. can it be that?
rice_classic
21
Apr 10, 2013 09:59 PM
Sammyloski
Jun 24, 2009 05:14 PM
FritzInTN
Jun 27, 2004 09:43 PM
