OBDII to OBD1 ...what are the related problems ? only need adapter ?
Old Sep 3, 2001 | 03:51 PM
JinMTVT's Avatar
New User
Default OBDII to OBD1 ...what are the related problems ? only need adapter ?
is there anything else needed to have that work ??
will the SRS system still work ?
what about the security coded key system ??
is there anything else we need to rewire and change when doing this swap ?
thanks
Old Sep 3, 2001 | 07:31 PM
HXMan's Avatar
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (JinMTVT)
Nope...just the OBD1 ECU and adaptor.
Yes, independent of the ECU.
Yes, independent also.
No.
Old Sep 3, 2001 | 07:51 PM
JinMTVT's Avatar
New User
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (HXMan)
are u serious ??
it's a direct plug and play ??
mmm
that's even more interesting ahahaha
eheh
tanx ..
Old Sep 4, 2001 | 07:18 AM
HXMan's Avatar
Yep, plug n play.
Old Sep 4, 2001 | 10:04 AM
ZygSpeed's Avatar
You sure about this one?
Old Sep 4, 2001 | 12:00 PM
H23 Power's Avatar
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (zygspeed)
the coded key wont work...thats built into the ECU
well, your key will work fine...but its not going to be protected like it was...the coded key will be useless
Old Sep 4, 2001 | 01:33 PM
JinMTVT's Avatar
New User
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (01GSR)
that's what i thought too ..
but then again ..
bring the obd1 ecu +adapter when i need the power ..(track day )
and put in the the obdII ecu when i need the security ( in town )
that's the good point of it if it's as PNP as u are telling me
Old Sep 4, 2001 | 02:39 PM
HXMan's Avatar
When you said key code I thought you were talking about keyless entry....what honda has a coded key?
My Hondata Stage 3 with OBD1 conversion should arrive this week. It is plug n play.
Old Sep 4, 2001 | 02:54 PM
fixhondas's Avatar
They call it an immobilizer system- it reads a chip in the key and then the ecu enables fuel relay. The ecu stores key information. The ignition switch has a transceiver in it that powers the key and reads it.
Old Sep 4, 2001 | 08:24 PM
HXMan's Avatar
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (fixhondas)
Hey, thanks.
But what car does it come with?
Old Sep 4, 2001 | 09:16 PM
StinkyTofu's Avatar
is it really worth it to change your car from OBDII to OBDI? I've seen alot of OBDII equipped integras wipe out OBDI integras...Of course with different mods, but the b18c1 still responds very well to mods even with obdII.
Old Sep 5, 2001 | 07:06 AM
JinMTVT's Avatar
New User
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (IntegraGSR)
nah
my car is prelude 97
and there is jsut NO WAY to tune ecu except from obd1 still ..
unfortunatly..
i wanted to get spoon program for h22a..with small modifications
Old Sep 5, 2001 | 07:59 AM
bigTom's Avatar
as for your security with the key code and whatnot... any amateur thief will have an ecu with the code disenabled and just plug it in... the code in actuality is worthless imo
Old Sep 5, 2001 | 09:42 AM
JinMTVT's Avatar
New User
Default Re: OBDII to OBD1 ...what are the related problems ? only need adapter ? (ek9t)
ah ...is that how they ****** disable it ?
**** ..didn't thought of that ..
eheh
neway here when they steal ur car..
they brake the window with tape, open the hood...cut the battery cable
and TOW the car
eheh
GsRrrr
May 24, 2010 03:43 PM
Type_BB6
Mar 2, 2010 03:23 PM
elpiar
Mar 29, 2005 03:48 PM
Thagreybomber
Jun 17, 2002 09:17 PM
