Need oil feed adaptor for Greddy Td05H - 15G SOHC turbo
Old Oct 21, 2003 | 05:57 PM
Bailhatch's Avatar
Default Need oil feed adaptor for Greddy Td05H - 15G SOHC turbo
I need the adaptor that goes from -3AN oil feed line to the inverted flare fitting on the turbo. This is the the TD05H - 15G from the 92-95 civc EX/Si kit, just to clarify.
It would be great if I could get the fitting overnighted. If any one knows a website or something, hook me up with the address! TIA
Old Oct 21, 2003 | 06:35 PM
Ricey McRicerton's Avatar
Default Re: Need oil feed adaptor for Greddy Td05H - 15G SOHC turbo (Bailhatch)
I don't know, but you can try Greddy. I don't think they will part out kits, but bump for a guy with the same kit as me!!
EDIT: That kit used a TDo 4 h-15g
Old Oct 21, 2003 | 07:33 PM
Boltz's Avatar
Default Re: Need oil feed adaptor for Greddy Td05H - 15G SOHC turbo (Ricey McRicerton)
golden eagle has an oil inlet hookup
Old Oct 22, 2003 | 07:53 AM
Bailhatch's Avatar
Default Re: Need oil feed adaptor for Greddy Td05H - 15G SOHC turbo (BoostRotter)
update - I had an automotive supply shop make me up and adaptor/ 90 degree out of some brake line. looks like it will work, just won't be reall pretty.
oh, i just copied what was in the greddy catalog for the turbo size. td04 it is then.
i'm building a custom kit for someone useing a HF manifold. It looks like it will be a hard one to fit since you have limited ability to clock the turbo how is the turbo mounted normally? compresssor on the passanger side?
edit -- on the greddy website it says TD40H-15G...close
xander1100
Apr 28, 2009 08:18 PM
ek9 ferio
Mar 28, 2005 08:42 PM
ATS*Mark
Oct 29, 2003 12:37 AM
Happyman
Aug 16, 2003 01:10 PM
