B18A swap into EG (automatic!!!!)
Old Oct 21, 2003 | 02:28 PM
SpeedMonkeyRacing's Avatar
Default B18A swap into EG (automatic!!!!)
has anyone done this swap before? I bought one from the junkyard FAIRLY cheap and I wanna swap it into my 93 civic dx (automatic as well). Now, I need to know what I have to do to complete teh swap (considering auto trannies are all same in all years isn't it?). What mounts would I need? I was thinking about using 0bd1 integra ecu (automatic) and everything else off that b18a (is that okay?). All helps are welcome..thanks in advance.
Jeff-
Old Oct 21, 2003 | 02:35 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Your going to put a 90-93 integra motor in there? Should just do a 94+ Integra motor so it will bolt up.
Old Oct 21, 2003 | 02:38 PM
Default Re: (1 point 6)
well, I thought that engine side of the mount will bolt right in. since it's automatics...it should bolt on w/o any problem as well (crx's are like that but i dunno about eg's). And plus it's NON-VTEC so i don't have to wire extra wires. Plus I think I can find me a 94~95 Integra nonvtec automatic ecu's fairly easy and that should plug right up. It's all thinking right now..I would like to know what you guys think about this...
P.S - I have several B20 long blocks so i'm not afraid to throw that **** in instead. Also i have those injectors so I can avoid that "resistor" box type of deal. What do you think?
Jeff-
Old Oct 21, 2003 | 02:45 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
I understand what your saying just seems like a lot of extra BS just for 130hp. I would go the b20 route, cause you can always slap a vtec head on it.
Old Oct 21, 2003 | 03:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">I understand what your saying just seems like a lot of extra BS just for 130hp. I would go the b20 route, cause you can always slap a vtec head on it.</TD></TR></TABLE>
well, hp is not a problem. i'm planning to do more than that i just need to knwo if any ever done this swap and what problems will i run into?
Jeff-
1990civic4door
14
Apr 19, 2010 02:25 AM
Rsporty
Feb 13, 2010 05:29 AM
hybridtheory4303
Nov 10, 2008 12:16 PM
evileg8
Aug 31, 2007 06:18 PM
SpeedMonkeyRacing
Oct 29, 2003 07:53 AM
