Nitrous fuel upgrades
Old Oct 21, 2003 | 02:02 PM
1boostedcivic's Avatar
Default Nitrous fuel upgrades
Current Mods:
1995 d16z6
i/h/e
aem cam gear
msd ignition
Plan on spraying 75 shot with the following upgrades: fuel pump, regulator, filter and maybe some 270cc injectors tuned with Hondata.
Besides colder plugs, what else do you guys recommend?
Old Oct 21, 2003 | 02:18 PM
Sketch_hs's Avatar
Default Re: Nitrous fuel upgrades (1zexxedcivic)
JDM fire extinguisher y0!
actually sounds like you thought this out pretty well.
Old Oct 21, 2003 | 02:27 PM
JICEK9's Avatar
your on the right track.
good luck
Old Oct 21, 2003 | 02:36 PM
jameskersten1's Avatar
Default Re: Nitrous fuel upgrades (JICEK9)
what pressure you plan on running the nitrous at?
Old Oct 21, 2003 | 10:56 PM
Mista Bone's Avatar
D Tranny Guru
What kit you using???????
My rundown.......
ZEX at 85 shot, 325 cc/min injectors, MSD 6AL, Champion plugs. Normal fuel sysytem upgrades also.
Cam gear is not really needed. Use it to retard the cam 2-3 degrees to lessen the cylinder pressure below 5000 rpm under juice.
Old Oct 21, 2003 | 11:23 PM
97hb's Avatar
Default Re: Nitrous fuel upgrades (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote"> Champion plugs</TD></TR></TABLE>
Hey Mista Bone, Why do you use the Champion and not the NGK's?? Any difference.
Old Oct 21, 2003 | 11:52 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Nitrous fuel upgrades (97hb)
Champions don't melt the ground strap as easy...........
ZEX at 85 shot and LEAN!!!!!!!!!!!
Learn to read the heat stripe......
Old Oct 21, 2003 | 11:54 PM
IWearMyKswiss's Avatar
New User
ive been running zex plugs for as long as ive been running nitrous (2 years) and ive had no problems with them
Old Oct 22, 2003 | 07:03 AM
blackeg's Avatar
Default Re: Nitrous fuel upgrades (WiDeBoDyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK &raquo;</TD></TR><TR><TD CLASS="quote">ive been running zex plugs for as long as ive been running nitrous (2 years) and ive had no problems with them</TD></TR></TABLE> good to hear. i just got the zex plugs for my nitrous setup. theoretically they should work cause they were designed by zex for nitrous/turbo to prevent detonation.
JDMDC4life
Oct 12, 2006 02:18 PM
blackeg
Dec 26, 2003 08:37 AM
1boostedcivic
Nov 11, 2003 09:08 PM
Sohc Driver
Dec 14, 2002 02:58 PM
CM-R
May 7, 2002 01:43 PM
