Autometer A/F gauge and bad O2 sensor readings
Old Oct 21, 2003 | 11:16 AM
madman604's Avatar
Default Autometer A/F gauge and bad O2 sensor readings
I have read that the A/F gauge will couse incorrect readings to be sent to the ECU causing tuning issues. is this true? the gauge decreasing the voltage?
I just picked up an Autometer unit and wanted to know before i hooked it up.
Old Oct 21, 2003 | 06:03 PM
madman604's Avatar
anyone?
Old Oct 21, 2003 | 07:04 PM
Ricey McRicerton's Avatar
Default Re: (Turbo E)
IMHO the Autometer A/F guage is nothing more than a nice light show. If you are using this thing to tune, don't. Just get a wideband 02 now. You can get one for under 350.
Old Oct 21, 2003 | 07:08 PM
libila's Avatar
Agreed that air/fuel gauges are ******* jokes. I have one in my 2g dsm and the only time its accurate is WOT. Screw those things.
Old Oct 21, 2003 | 07:11 PM
XSIintegra's Avatar
Default Re: Autometer A/F gauge and bad O2 sensor readings (Turbo E)
I believe this is true. I installed a Apexi turbo time w/ the A/F gauge. While working to track down a bad wire, I had to use a volt/ohm meter. While doing so, I realised that if I put the meter on the O2 wires and read the voltage (this is with the car off-so it should stay constant), the voltage reading at the A/F gauge would change. I believe there is a small bleed off of power, but very little since the meters only use the power coming from the O2 sensor as a reference and not a power supply.
nytosc
Aug 23, 2008 07:40 AM
hondaguyexsi
Oct 8, 2005 06:58 PM
photonjedi808
25
Apr 17, 2003 12:08 AM
dariusz
May 8, 2002 03:13 AM
