wut's engine head gasket for?
Old Oct 20, 2003 | 10:43 PM
kool168's Avatar
Default wut's engine head gasket for?
wut's the function of the engine haed gasket?
it increase the compression, so it will make more power?
if so, then which gasket is the best?
Old Oct 20, 2003 | 10:48 PM
00 FBP ItR's Avatar
Default Re: wut's engine head gasket for? (kool168)
You don't need one.. just use a sheet of foil, it'll bump your compression even more.
Old Oct 20, 2003 | 10:58 PM
nightrider's Avatar
Default Re: wut's engine head gasket for? (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">You don't need one.. just use a sheet of foil, it'll bump your compression even more.
Old Oct 20, 2003 | 11:02 PM
kool168's Avatar
Default Re: wut's engine head gasket for? (nightrider)
a sheet of foil?
so it increase your power?
Old Oct 20, 2003 | 11:07 PM
B2FiNiTY's Avatar
He's joking. The headgasket prevents coolant out from the oil and keeps oil from leaking.
Old Oct 21, 2003 | 12:06 AM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kool168 &raquo;</TD></TR><TR><TD CLASS="quote">wut's the function of the engine haed gasket?
if so, then which gasket is the best?</TD></TR></TABLE>Wow this should win question of the month award
Old Oct 21, 2003 | 01:53 AM
NA gs-R 05 C
Guest
Posts: n/a
lol, good one.
Old Oct 21, 2003 | 07:45 AM
Flux's Avatar
Default Re: wut's engine head gasket for? (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Wow this should win question of the month award </TD></TR></TABLE>
And how is that? If he doesn't know what a headgasket is, then what is wrong with asking? I don't get this place sometimes....
Old Oct 21, 2003 | 07:49 AM
hungsteR's Avatar
Default Re: wut's engine head gasket for? (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
And how is that? If he doesn't know what a headgasket is, then what is wrong with asking? I don't get this place sometimes....</TD></TR></TABLE>
H-T isn't exactly what it used to be. Especially the ITR forum.
Old Oct 21, 2003 | 07:53 AM
TyPe_R_GuY's Avatar
and it also plays a roll on keeping the pressure in the cylinders from leaking out as well
Old Oct 21, 2003 | 09:03 AM
Padawan's Avatar
Darth ModerVader
Your engine already has a head gasket, and it's function is the same as any other gasket - to create a seal between two surfaces (in this case, the block and the head).
There are companies that manufacture thinner head gaskets that do increase compression, and thus make more power. Basically, Spoon and Mugen are the two most commonly used thinner gaskets, with the majority of people (at least from my observations) using the Mugen piece. We installed one on my brother's engine, and have had no problems with it.
Old Oct 22, 2003 | 07:55 AM
kool168's Avatar
Default Re: wut's engine head gasket for? (Padawan)
finally got the answer....
thankz padawan
just wondering wut's forum for... if i knew the answer, then i wouldn't post the question...
Old Oct 22, 2003 | 10:07 AM
GettaluvR's Avatar
New User
same here ! some people are mean as hell here on H-T, u learn it by asking, unless you know all this when u were borned.
negusjuda
May 23, 2013 02:57 PM
EF88Vtec
Oct 12, 2008 09:06 PM
zx2gotboost
39
Dec 23, 2005 11:21 AM
HondaHead211
Aug 23, 2005 10:56 AM
btrim23
Apr 27, 2004 01:08 PM
