Why do I want to raise compression?
Re: Why do I want to raise compression? (zx2gotboost)
the y8 is from the 96 to 00 ex's, and if your boosting you want to lower your compression, so you kinda made your self look ignorant
* B A N N E D *
Re: (Djaric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">Get the correct head gasket for your motor. a little thicker or thinner gasket isn't going to do squat.</TD></TR></TABLE>
on H22s the stock head gasket is 30 thousandths (.030) if you get a thinner one, say .015 your compression will bump about .5 points. (10:1 to 10.5:1).
and a bump in compression of this order will give you about a 4-6% increase in torque across the board.
You should see the same % numbers on the SOHC, just working with smaller numbers. I'd say go for it, you're probably only shaving .005 or so (5 thousandths) but if they cost the same who cares. Just remember for every .015 you remove between the cam gears and the crank you're retarding timing about half a degree (calculated with H22 cam gears which are about the same diameter as the D-series ones) so you might loose the power you gained unless you have an adjustable cam gear.
Hope this helps.
Hope this helps.
Re: (SlowAzEg)
ohh my god, what ******* CIVIC has the thinner gasket that will work on my 1.5L SOHC NON VTEC? I rememebr someone saying Civic 96-00 But what modle EX or DX, someone said the EX is VTEC!!! I aM NON VTEC!
Re: (zx2gotboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zx2gotboost »</TD></TR><TR><TD CLASS="quote">aight, I just bough the D16Y8 head gasket, I hope its the SAME match as my D15b7 Cuz My d15b7 is NON VTEC and the D16y8 is Vtec . </TD></TR></TABLE>
hey fucktard, settle down. Vtec or not makes no difference with your gasket, so stop shitting yourself. The y8 gasket is thinner than the other oem ones and WILL raise your compression (despite what some other moron said). As for what is affected by raising your compression, refer to what h22mike said. You could have had the answer to all of your bitching and moaning alot sooner if you had actually read what the others had told you.
ok, here is the freaking deal, I bent some valves on my priveious head, thankfully I have a BRAND new HEAD that I seriously polished the out side and ported & polished the ports, therefore I have to get a new head gasket, so why not get the Y8 gasket? since its off....
by the way, I am sorry for being a damn noob, and for the bumb *** replys, its hard to commmunicate/ understand what peeps are saying by typing. But I DO apprciate yalls help very much!!!! Thank you!
Re: (joe jigga)
How high do you think my compression is right now..? I have
D16Y8 Head gasket, Brand new head with valves and valve job, Adjusted valve lash perfectly, andCylinders honed...?
Modified by zx2gotboost at 9:01 PM 12/19/2005
Re: (tuck'd98)
btw if you have a d15 a y8 head gasket wont work d15 with d15, d16 with d 16 its as simple as 1+1 plus
your compression will be close to stock compression if not the same, y8 headgasket, wrong one!, brand new valves and valves valve job?? whatever that is? cylinder honing, squat, brings your compression back to stock numbers across the boards no performance gain over stock, valves adjusted perfectly, they should be perfect anyway
Re: (zx2gotboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zx2gotboost »</TD></TR><TR><TD CLASS="quote">ITS metal! </TD></TR></TABLE>
lol i hope
lol i hope
Re: (tuck'd98)
1 LAST question............. Timing is oviously off, https://honda-tech.com/zerothread?id=1469420 Will I expletive anything up if I drive it for one more day like this>????
its scary that this guy is going to boost/swap his car...you arent going to attempt to install the turbo kit and swap the car are you? you definatly need to do some research before you ask stupid questions.
sorry for the assholish comment.
