Brake Upgrade Suggetions
Old Aug 4, 2002 | 04:30 AM
turbo Si's Avatar
Default Brake Upgrade Suggetions
Ok here is my delima. I have a '99 Si. I need a more responsive brake setup although I can't go bigger than stock due to my 13 inch Bogarts that I use at the track. Someone told me that Willwood might make a two piston caliper that will be equivilent in size to the stock caliper, although that is not for sure. I don't want to spend thousand's of dollars on a setup. I am sure people on this forum have gone through this problem so your information will be greatly appreciated.
Thank You, David!
Old Aug 5, 2002 | 07:52 AM
CivicNewbie's Avatar
Default Re: Brake Upgrade Suggetions (turbo Si)
http://www.fastbrakes.com
Old Aug 5, 2002 | 08:21 AM
CheezeFrog's Avatar
Wilwood makes a Civic kit that uses Dynalite calipers (not sure if it's Dynalite or Dynalite II's) with rotors and pads for $606 from Jegs. It's not on their website, but it's in the current Jegs catalog. Fastbrakes sells a similar kit for $8xx.
Edit: If you want to keep your 13" wheel'ability, you might have to relegate yourself to using upgraded stock sized pads & rotors. Min wheel size on the Wilwoods is 15" -- at least on the Fastbrakes kit.
[Modified by CheezeFrog, 9:23 AM 8/5/2002]
Old Aug 5, 2002 | 08:24 AM
93LSivic's Avatar
Actually a lot of people just suggest some good brake fluid and some quality pads--something like HAWK pads.
I bet you can get some better replies in the RoadRacing/Autocross forum. I think most people here just care about getting there faster and worrying about braking when the time comes
Old Aug 5, 2002 | 08:41 AM
b18bturbo's Avatar
Default Re: Brake Upgrade Suggetions (93LSivic)
get the porterfield pads . They are aweseome.. i might do a gb on them soon.
Old Aug 5, 2002 | 01:46 PM
turbo Si's Avatar
Default Re: Brake Upgrade Suggetions (b18bturbo)
Thanks for the rplies guys. My friend works or Porsche's and he recommended Hawk or Padget brake pads. He also wanted me to go with a rotor that will release heat quicker and some seel braided brake lines so they don't flex.
Old Aug 5, 2002 | 03:39 PM
SIK IN DA HED's Avatar
New User
how much do those pads usually run? how about hawk pads?
Old Aug 5, 2002 | 05:01 PM
KekeK-18's Avatar
Default Re: Brake Upgrade Suggetions (dlplayboy)
porterfield r4s are really good for street and autox they are kinda pricey though, about 100+ for the front and Hawk hp+ are also really good for 60-70 for a front set.
If you want to use 13" wheels, just get some new blank rotor, a set of good pads and ATE fluid.
Vspronk
Aug 28, 2015 11:56 AM
inline976
Honda S2000
May 13, 2007 04:34 PM
clin20
Jun 7, 2004 08:30 AM
boosted_dc2
Oct 20, 2003 10:11 PM
Short_Shifter
Dec 27, 2001 12:57 PM
