jdm b16a vtec!
Old Oct 20, 2003 | 08:29 PM
youngsters69's Avatar
Default jdm b16a vtec!
i have a jdm b16a in my 93 civic si hatch.
i cant really feel the power or hear the vtec kick in.
what upgrades must i do before i can start feeling the vtec and hear it?
what bolt-ons?
Old Oct 20, 2003 | 08:49 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: jdm b16a vtec! (youngsters69)
Take your airbox off.
Old Oct 20, 2003 | 08:53 PM
Default Re: jdm b16a vtec! (Mr Milano)
what do i replace my airbox with? what other mods do i have to do?
Old Oct 20, 2003 | 08:54 PM
STEALTHMODECOUPE's Avatar
in my 00 Si w/ the OEM airbox you really cant feel or hear nothing..with a AEM shortram you still cant really feel much but its one of the coolest sounds you honda will make when hitting vtec now w/ the OEM airbox back on i removed the whole bottom piece and it makes a cool low end noise and you can actually feel vtec kick ina little but no loud vtec its a win lose situation
**edit** buy my AEM shortram from me..its the best first mod for the b16 you wont regret it
adaM
Old Oct 20, 2003 | 11:12 PM
theslugbug's Avatar
what ecu are u using??? u should be able to at lease hear vtec. is everything hook up right?? any check lights??
Old Oct 20, 2003 | 11:38 PM
bossman032's Avatar
Default Re: jdm b16a vtec! (alllgo)
if your vtec don't scream then their is something seriously wrong with a swapped motor. or maybe because u have stock piping will make ur vtec not scream!!!! vtec should scream never the less unless you have those 99si those vtec don't scream like swapped motors I don't know why..
Old Oct 21, 2003 | 06:59 AM
SICKSOLSI's Avatar
Default Re: jdm b16a vtec! (bossman032)
if you cant hear vtec kick in on a b16 theres seriously something wrong my friends si with a stock airbox still screamed when it hit the crossover
Old Oct 21, 2003 | 12:01 PM
Default Re: jdm b16a vtec! (95excoupeMT)
i have a jun ecu, and it limits my reving to about 7200 rpm. but i feel alot of power from beginning to about 7000 rpm with this ecu. i like this one. everything is connected properly. i see the rpm rev fast when it reaches about 6000 rpm. maybe my ecu control my vtec at about 6000 rpm. but i cant really hear anything. i have everything stock on the motor. maybe thats why. i have a straight pipe but hooked on a stock muffler. thats about it.
Old Oct 21, 2003 | 12:12 PM
-KangaRod-'s Avatar
are you sure its not an LS ecu? what is the part number on the ecu. If you have to ask if you B16 is hitting vtec, then its not. B16's are dogs, then when vtec engages it goes like a **** (nevermind the sound, which you should hear, bu you should definitely feel the pull)
A rev limit that low is also a bit disturbing....
Try and run it with a good P30 ecu.
Old Oct 21, 2003 | 01:59 PM
Default Re: (-KangaRod-)
i're tried the p28 chip which gives me unlimited reving. but i lose a little bit of power after 7800 rpm. even though i can rev up to 9000 rpm with the p28, i dont feel as much pull as my ecu. i havent tried a p30 yet. i can see the rpm rise very fast but i cant really hear or feel it much. maybe because its stock. but i'm sure my vtec does kick in because i see the rpm rise like hell! which ecu is best for my jdm b16?
Old Oct 21, 2003 | 03:00 PM
philafelman's Avatar
Default Re: (youngsters69)
just take off you intake and unbolt your exhaust and take it down the street, you should hear it then.
Old Oct 22, 2003 | 12:48 PM
Default Re: (philafelman)
what intake, headers, and intake manifold is best for me?
for a stock jdm b16a like mine, at what rpm does vtec kick in?
Modified by youngsters69 at 10:09 PM 10/22/2003
Old Oct 23, 2003 | 01:15 PM
should kick at 5500rpms i believe.
Old Oct 23, 2003 | 07:24 PM
DX187VTEC's Avatar
start off with your basic intake and exhaust but figure out your prob first..... unbolt your exhaust like said, you will hear it cross..... intake mani is nothing you should be concerned with right now you will lose hp with aftermarket intake mani's at this piont.....good luck bro.....
Old Oct 23, 2003 | 09:32 PM
Default Re: (DX187VTEC)
thanks for the tip! so at what point should i worry about installing an intake manifold? after i get my basic bolt-ons like intake, headers, and straight pipe? what other bolt-ons do u recommend before i can get to the stronger upgrades?
thanks
Old Oct 23, 2003 | 11:20 PM
CleenSi
Guest
Posts: n/a
Default Re: jdm b16a vtec! (STEALTHMODECOUPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE &raquo;</TD></TR><TR><TD CLASS="quote">in my 00 Si w/ the OEM airbox you really cant feel or hear nothing..with a AEM shortram you still cant really feel much but its one of the coolest sounds you honda will make when hitting vtec now w/ the OEM airbox back on i removed the whole bottom piece and it makes a cool low end noise and you can actually feel vtec kick ina little but no loud vtec its a win lose situation
adaM</TD></TR></TABLE>
TRU THAT!
Old Oct 23, 2003 | 11:25 PM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngsters69 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the tip! so at what point should i worry about installing an intake manifold? after i get my basic bolt-ons like intake, headers, and straight pipe? what other bolt-ons do u recommend before i can get to the stronger upgrades?
thanks</TD></TR></TABLE>
build the cylinder head up by simply purchasing cams/valvesprings/retainers and all that BullShit, then once you get those things then u can worry about a SKUNK2 Manifold, or a Type R throttle body.
good luck with the whole setup tho. hope it works out.
Old Oct 24, 2003 | 11:32 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngsters69 &raquo;</TD></TR><TR><TD CLASS="quote">what intake, headers, and intake manifold is best for me?
Modified by youngsters69 at 10:09 PM 10/22/2003</TD></TR></TABLE>
Depending on what ECU you have that will determine when VTEC kicks in. I have a PR3 ECU and VTEC kicks in at 5,200 RPM, and with a stock air box I can definitely hear the VTEC switchover.
Old Oct 24, 2003 | 11:53 AM
Default Re: (SiRWanabe)
well, whats the best ecu that you recommend? i have a jun ecu. i think my vtec kicks in about 5500 rpm. somewhere right there. what bolt ons do u recommend for that ecu? thanks!
Old Oct 24, 2003 | 01:14 PM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngsters69 &raquo;</TD></TR><TR><TD CLASS="quote">well, whats the best ecu that you recommend? i have a jun ecu. i think my vtec kicks in about 5500 rpm. somewhere right there. what bolt ons do u recommend for that ecu? thanks!</TD></TR></TABLE>
I would get the stock ECU for starters, then send in to http://hondata.com/
and they will work wonders with it.
malo11
21
Dec 24, 2022 04:57 PM
xkhalil333x
Apr 25, 2009 08:17 AM
RichardDiaz2005
Honda Civic (2001 - 2005)
46
Jul 6, 2007 08:06 PM
CrX-WoRlD
Mar 20, 2007 06:54 PM
CrazyRexBoy
Oct 27, 2006 11:10 PM
