need someone to diagnose this problem.. ecu related.
Old Oct 20, 2003 | 05:51 PM
DC2_Integra's Avatar
Default need someone to diagnose this problem.. ecu related.
okay this is how the problem occured. i just installed a sk2 im and threw my p28 with a jun chip in it. Then my car ran like ****, threw like 3 codes. I didnt feel like working on the car anymore, and i was just gonna check it out another day. So i decided to just but my stock obd2 p72 chip back into the car (if its not gonna run right, might as well save some gas for the time being) and then all the codes were gone.. My car was perfectly normal.. So i thought maybe the Jun chip was was too rich, running in open loop, so i went and ordered a J's racing hybrid chip(runs closed loop). And today i went and installed that chip, and it still runs like ****. threw some codes is in limp mode. Wont go over 4k rpm. Anyone ever experience problems like this??
to summarize it: intalled sk2 im, put my p28 chipped jun in, threw codes run like ****, change jun to J's hybrid, still ran like ****. what are the possibilities?
Old Oct 20, 2003 | 05:54 PM
eg6ajk's Avatar
Default Re: need someone to diagnose this problem.. ecu related. (DC2_Integra)
if you were unable to rev past 4k rpm while driving then the issues is with either the chips or ECU.
-chips either wrong program or inserted the wrong way or simply lost data (static)
-ECU could be damaged or not chipped properly.
Old Oct 20, 2003 | 06:08 PM
Default Re: need someone to diagnose this problem.. ecu related. (eg6ajk)
let me try flipping the chip. maybe i inserted it wrong.
Old Oct 21, 2003 | 10:32 AM
okay i got the codes 3, 21, and 22 with the Jun chip. And with the J's hybrid i get a code, 0 (0 is when it stays on, and not blink right?)
Old Oct 21, 2003 | 08:43 PM
what do u think guys?!?! Im just confused because only the J's racing chip gives me a ecu defect code, and the Jun chip gives me the Vtec and map sensor code. And my stock OBD2 wont give me any code. SOmeone help me out!
Old Oct 21, 2003 | 09:01 PM
RedZone's Avatar
3 is map sensor, is it plugged in and if so did you mix it up with the TPS. 21 is the Vtec solenoid and 22 is the vtec pressure. make sure they are all plugged in, as for the J chip its bad, solid light means the chip is no good. hope this helps out.
90CB7EX
Apr 10, 2011 02:23 PM
jdmdikk
22
Jun 30, 2009 06:04 PM
prwil3030
11
Feb 16, 2007 08:30 AM
siekhatch
Jun 5, 2006 01:58 PM
DC2_Integra
Oct 21, 2003 09:03 PM
