Quad throttle bodies on ZC...what numbers can i expect ?
HI - just a quick question - as since my Si civic ( in oz, with a ZC spec enigne)
has been just written off by a van from behind...i have considered using ( becoz of originality and lack of funds) usign my existing engine, plus parts form the car upon a fresh shell , and a 4 throttle style setup...will be run ALLMTR , wil full interior strip , pull out all teh weight i can etc...
I realise that a 4 throttle setup does make more power - but at what cost and what level compared to stock ???
( BTW 130 hp stock)
I think it woudl be a unique and cheaper alternative to sticking a totally new engine in wit vtekk or whatever...
Thoughts ???
( BTW 130 hp stock)
Thoughts ???
my guess is 15whp at most and at top rpms only.... but with excellent tuning you may gain across the rev-range.
itb's breathe better and usually that is the only thing shown on a dyno... at higher rpms too.
you can get faster throttle rtesponse from itb's but tuning is the key. and even with hondata or aem ems they seem to be a pisser... with non-honda-ecu setups you can do better but lose streetability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennnjamin »</TD></TR><TR><TD CLASS="quote">HI - just a quick question - as since my Si civic ( in oz, with a ZC spec enigne)
( BTW 130 hp stock)
Thoughts ???
i have a TWM ITB manifold on my h22 and you absolutely need to get a stand alone to run it correctly. i use AEM PMS. tuning is a MF. i have been in a type r with the same set up and it ran fine with a fields vtec controller some how, but i still dont know how. my car is 100% driveable but as a pretty penny and mine still isnt running right hp wise. the manifold alone is big money like $2400 big. i dont even know if any one makes a manifold for ZC or single cams. best bet is to run a b16 swap. just as fast if not faster and a whole lot more potential.
( BTW 130 hp stock)
Thoughts ???
</TD></TR></TABLE>i have a TWM ITB manifold on my h22 and you absolutely need to get a stand alone to run it correctly. i use AEM PMS. tuning is a MF. i have been in a type r with the same set up and it ran fine with a fields vtec controller some how, but i still dont know how. my car is 100% driveable but as a pretty penny and mine still isnt running right hp wise. the manifold alone is big money like $2400 big. i dont even know if any one makes a manifold for ZC or single cams. best bet is to run a b16 swap. just as fast if not faster and a whole lot more potential.
i'm almost done making ITB's for my zc. i just put a milled/PP/3 angle vavle job head on, cometic headgasket, and custom exospeed stage 2 cams in w/srr cam gears and it rips right now, cant wait to get the ITB's on. i'm using a setup from a cbr 954 motorcycle and making a custom manifold. should be on in a month. i'm gonnna be running ghettodyne for managment. according to the compression calculator, my car now has 10.6:1 instead of 9.6 i believe. big difference on the top end already.
Vtec04
Engine Management and Tuning
Nov 8, 2017 12:56 PM
xxvinxx43
18
Aug 10, 2011 10:31 PM
StinkyTofu
Apr 17, 2003 05:50 AM
