how reliable would 350hp be on stock LS sleeves
Old Oct 20, 2003 | 04:06 AM
civictypenos's Avatar
Default how reliable would 350hp be on stock LS sleeves
i know this probably gets asked alot,but im in the process of building,i dont really want to spend money on sleeves unless its neccesary.
set up would be ,b16 head on a Ls block,with a t3/to4e pushing around 15 psi.tuned with wideband and vafc.
my goal is about350 hp max at 15 psi,but mostly would be ran around 10 psi daily.
the block would have eagle rods with the bigger bolts and a set of je pistons with a comp somwhere around 9.5:1.i might put a block gaurd on also.
just need some thoughts on what real time users on here have been through with stock sleeves.
Old Oct 20, 2003 | 04:51 AM
g2turbo's Avatar
Default Re: how reliable would 350hp be on stock LS sleeves (civictypenos)
it would be fine if tuned correctly. I would personally get hondata or something similar instead of the vafc.
Old Oct 20, 2003 | 08:04 AM
chidoks's Avatar
it would be as realible as your tuner
Old Oct 20, 2003 | 10:16 AM
Mr. Softee's Avatar
Default Re: how reliable would 350hp be on stock LS sleeves (chidoks)
people make 350whp on stock gsr motors... 350whp on a semi built ls/vtec should be a breeze with a good tuner and a solid all around setup.
Old Oct 20, 2003 | 10:27 AM
Default Re: how reliable would 350hp be on stock LS sleeves (94goldjungsr)
thanx guys,i was thinking it would not be a problem,as for a tuner,vaportrail (john) is only about a hour away.
Peligro
May 21, 2007 04:10 AM
DJone850
Dec 3, 2003 04:55 PM
blueturbo4door
Jul 29, 2003 08:51 PM
USDMMARK
Feb 9, 2003 01:58 AM
TheSwift1
Jul 2, 2002 05:53 AM
