H22a or B18c
Old Oct 19, 2003 | 04:37 PM
KenRed's Avatar
Default H22a or B18c
Im having a hard time choosing between getting a Honda Accord and Swapping out and putting a H22a, or get a Civc EX and put a B18 JDM 180hp motor, but my goal is to either out run a ZO6 or either keep up with it, I know a turbo kit that will give me the extra 200whp over the stock whp, but Im not sure what motor to go with so ppl i need help thanks.
Old Oct 19, 2003 | 05:02 PM
JC VTEC's Avatar
Default Re: H22a or B18c (KenRed)
i'll take the civic with b18c.
Old Oct 19, 2003 | 05:06 PM
JSMC's Avatar
don't take it bad guys, but...
accord vs civic hmmm you can't compare them, accord got class, greatly modified it's a beautiful car, the only thing is missing is some power in this car.
a civic, well it's not an heavy car, and that's about it, a lot of pieces to customize it and engine that can take high rev (h22 can too, with more torque)
another thing, I hate those car where the weight is juste as important as the engine, i Hate a car that when you have 1 passenger or just do a full tank you loose performance.
some people would say that it's ridiculus to modify an accord on performance, tssss you got class and power, what do you need else
btw, on highway it's a charm cause of the weight
accord
Old Oct 19, 2003 | 05:13 PM
Tinker219's Avatar
Default Re: H22a or B18c (JSMC)
Civic EX w/h22a
Old Oct 19, 2003 | 05:18 PM
KenRed's Avatar
Default Re: H22a or B18c (Tinker219)
its a wee bit heavy dontcha think?
Old Oct 20, 2003 | 08:09 AM
chidoks's Avatar
No...its not
Old Oct 20, 2003 | 08:41 AM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KenRed &raquo;</TD></TR><TR><TD CLASS="quote">its a wee bit heavy dontcha think?</TD></TR></TABLE>
I remember someone doing a weight test with a JDM H22 and tranny with a JDM B18C1 with the tranny, and the only difference was like 50lbs(could be wrong but it wasn't much).
Old Oct 20, 2003 | 08:44 AM
chidoks's Avatar
Default Re: H22a or B18c (Bryson)
yes its about 50-80lbs difference
Old Oct 20, 2003 | 10:19 AM
KenRed's Avatar
Default Re: H22a or B18c (chidoks)
well what's a cheaper place for a H22a and tranny, and other stuff that goes along with that kit, and where could I find a JDM GSR motor as well?, cause the kit I saw on overboost.com, its a stage 4 kit, and can give 200+ so if my math is right, if I get that 200+ kit then im lookin at 420hp to the crank, and about 390 to the wheels on the H22a setup... also that turbo kit comes with every thing I need to get that 200whp over stock as well, and I think it also comes with the low compression pistions as well. Another site I know that comes with the internal work is http://www.sfp.net/customTurboKits.asp?id=29 for the B and D series, it says it can give about 140% over stock hp and whp. Another question, if I upgraded my Camshafts, and Valve Springs and go Turbo would that help, and i will also Sleeve my engine as well, so if u can help me then let me know somethin asap, and I live in Georgia so wheres a good place to install my engine, turbo, and dnyo the car once it's done, cause I live in Douglasville Ga, and the near biggest city is Cobb County.
Old Oct 20, 2003 | 10:43 AM
chidoks's Avatar
390 to the wheels on a stock internalled h22
Nox
Sep 22, 2004 03:39 PM
HondaPride
Apr 20, 2003 03:15 PM
el arbi
Feb 27, 2003 02:06 PM
LoudAccord
Oct 31, 2002 02:13 PM
