Injector question
Ok, so im putting my motor in my car, and im hooking up my injectors, and they arnt clipping all the way down, im searchin around for an answer with the clips or injectors and i notice that the inner clip guides are different...can anyone tell me the difference in these injectors, and if they will work in my OBD1 ls/vtec? I probly already know that one is saturated and the other is peak and hold...but im not sure...just looking for different answers
It will work with no problem. You just have to decide if you want to modify the injector clips to hook up, or buy some different injectors that will connect up with no modification, and sell those ones. But your computer will be able run them.
I thought you said in previous post your setup was obd0? If obd0 then you can run any injector. If obd1, you may need to wire up a resistor box. To verify which type you have there, you should be able to use a multimeter and measure there ohms of resistance. Does anyone know what numbers you should get? You could compare the ohms of resistance to the ohms of your oem ones.
Modified by Mach slo at 7:05 PM 10/19/2003
AmauryR
Nov 15, 2007 09:46 AM
boostedcivicsir
Jan 10, 2006 04:11 AM
