How can I tell?? (rims)
Old Oct 19, 2003 | 08:28 AM
T-Mo's Avatar
Default How can I tell?? (rims)
How can you tell if a rim is 4x100 or 4x114 etc? A keep getting little deals on wheels but, when I ask if they are 4x100 or 4x114 they get confused. One guy said the rims came off a civic, then 20 minutes later he said they came off of a Accord. Then I said, "accords and civics have different bolt patterns" and he said just bring the car up here so we can see. in which I didn't, because he sold tires and a few sets of rims and he didn't know what he was talking about. Bad business!
The other person I ran into yesterday had a set of rims and he didn't know the lug pattern either. He just said they should fit, but I want to be sure, so is there a way I can tell???
Old Oct 19, 2003 | 08:37 AM
EG8R's Avatar
Default Re: How can I tell?? (T-Mo)
Test fit on you car....
Old Oct 19, 2003 | 08:55 AM
T-Mo's Avatar
My car is not around at these times. Of course if the car was there I would have done that. My car has no tag, insurance, etc right now. These deals usually come through my job and friends of friends.
Old Oct 19, 2003 | 09:37 AM
neutron91's Avatar
Default Re: (T-Mo)
use a ruler
Old Oct 19, 2003 | 09:38 AM
T-Mo's Avatar
and measure what? the holes?
Old Oct 19, 2003 | 09:46 AM
NINJASPY's Avatar
Default Re: (T-Mo)
easiest way I always do it when I am at wheel shops is get your cell phone, pack of ciggerates, or even your fist/hand and measure the distance between lug holes on the wheels that are on your car, then walk around holding your measurement and compare it to other wheels...
Old Oct 19, 2003 | 11:53 AM
ThatRicerDaniel's Avatar
Default Re: (NINJASPY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASPY &raquo;</TD></TR><TR><TD CLASS="quote">easiest way I always do it when I am at wheel shops is get your cell phone, pack of ciggerates, or even your fist/hand and measure the distance between lug holes on the wheels that are on your car, then walk around holding your measurement and compare it to other wheels... </TD></TR></TABLE>
and then take pics with all the rims.
Old Oct 19, 2003 | 12:03 PM
Caleb V's Avatar
Default Re: (NitrousDreamz)
Find an old worn out hub from the junkyard, disassemble it alot of times after you take the drums off and pull/beat on on the hub the bearings will disassemble themselves leaving you with a hub and wheel studs in the correct pattern for your car.
Old Oct 19, 2003 | 01:12 PM
EG8R's Avatar
Default Re: (Caleb V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caleb V &raquo;</TD></TR><TR><TD CLASS="quote">Find an old worn out hub from the junkyard, disassemble it alot of times after you take the drums off and pull/beat on on the hub the bearings will disassemble themselves leaving you with a hub and wheel studs in the correct pattern for your car.</TD></TR></TABLE>
Thats a really good idea....
rotascircuit
29
May 1, 2009 09:00 PM
b20acura
Jan 31, 2007 01:44 PM
gribbs
Apr 20, 2005 09:40 PM
Xerxes3333
74
Apr 15, 2004 08:41 AM
BigIslandBoi
Jul 29, 2003 02:55 PM
