why isnt my vtec working
just put the z6 head on my a6 block,new valvetrain and stage 2 zex cam everything runs fine but my vtec isnt working, i can here my solenoid switching but no result anyone know what the problem is. I heard u have to run an oil line to the solenoid but i dont know.
I wouldn't do the vtec switch. I would sooner convert over to obd1. Because the Obd0 computer does not compensate for the bigger cams. Where as the vtec ecu gives you better ignition and fuel maps when you go into vtec. But i guess if you really want you can just do the switch.
Guest
Posts: n/a
Check your oil and make sure you have the proper ammount in there... or even if its old.... i dunno i remember my friend having the same problem and he jsut threw a nother quart in there and it was back up and running.....
Later
Later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nissanpwrds14 »</TD></TR><TR><TD CLASS="quote">no codes are showing I did forget to remove the oil control jet </TD></TR></TABLE>
I believe that could be your problem right there.
green91
Dec 29, 2004 06:43 PM
