JDM FD & ITR LSD into B16a2 tranny? Is it possible?
Old Oct 17, 2003 | 04:03 PM
_unknown_'s Avatar
Default JDM FD & ITR LSD into B16a2 tranny? Is it possible?
Another stupid question...
I used to have a '98 spec ITR tranny. Well I sold the motor. Now I am building up another. I have found a smoking good deal on a tranny from a '00 Civic Si.
What parts have to be changed for a JDM ITR Final drive and OEM ITR LSD to be installed into the B16a2 tranny?
Thanks in advance!!!
Old Oct 17, 2003 | 07:04 PM
B16GSR's Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (garth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garth &raquo;</TD></TR><TR><TD CLASS="quote">Another stupid question...
Thanks in advance!!! </TD></TR></TABLE>
just the main and counter shaft jdm first and final and oem lsd, just like doing a jdm final in an itr tranny, adding a lsd to the mix
others can correct if i am wrong
Old Oct 17, 2003 | 09:19 PM
smokey2.0's Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (B16GSR)
you'll need to modify the si tranny case, so that the ITR lsd can fit in it!
Old Oct 17, 2003 | 09:23 PM
K20EG's Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (smokey2.0)
how ?
Old Oct 17, 2003 | 09:53 PM
smokey2.0's Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (K20EG)
you'll need to take some material of the inside of the bell housing, you'll notice that when when you place the ITR LSD it will hit the inside of the case(bellhousing)
Old Oct 18, 2003 | 01:50 AM
SuperTwinz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">how ?</TD></TR></TABLE>They look like fins. Either break them off carefully or have them shaved. You'll see when you take out your diff.
Old Oct 22, 2003 | 10:48 AM
_unknown_'s Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (SuperTwinz)
So if I just want to run the ITR LSD in a Si tranny, all I have to do is modify the tranny casing. Or do I have to replace the final drive as well?
Old Oct 22, 2003 | 10:52 AM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTwinz &raquo;</TD></TR><TR><TD CLASS="quote">They look like fins. Either break them off carefully or have them shaved. You'll see when you take out your diff.</TD></TR></TABLE>
Never had to do this...
Old Oct 22, 2003 | 01:26 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garth &raquo;</TD></TR><TR><TD CLASS="quote">So if I just want to run the ITR LSD in a Si tranny, all I have to do is modify the tranny casing. Or do I have to replace the final drive as well?
the final drive has to be replaced..because the Si final is physically too small. The alternative is to get a EG6/EK4 OEM LSD.
But if you are changing to a 4.785, that is already taken care of if you want to use an ITR unit.
Old Oct 22, 2003 | 02:31 PM
_unknown_'s Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (RagingAngel)
Thanks for the reply.. that was the exact info I was looking for...
Old Oct 22, 2003 | 02:41 PM
igotyofire's Avatar
so itr lsd wont fit unless u change take the Si final drive out? is this relatively simple procedure puttin in a new lsd and final drive?
Old Oct 22, 2003 | 03:09 PM
bulori's Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (igotyofire)
one question i have a y8 tranny from my JDM GSR , can i isntall the final drive 4.785 without the ITR LSD or what?
Old Oct 22, 2003 | 03:56 PM
Big Teggie's Avatar
Default Re: JDM FD & ITR LSD into B16a2 tranny? Is it possible? (bulori)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">so itr lsd wont fit unless u change take the Si final drive out? is this relatively simple procedure puttin in a new lsd and final drive?</TD></TR></TABLE>
You need a 4.4 GSR/ITR ring gear to work with the ITR LSD. SI has a smaller ID.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulori &raquo;</TD></TR><TR><TD CLASS="quote">one question i have a y8 tranny from my JDM GSR , can i isntall the final drive 4.785 without the ITR LSD or what?</TD></TR></TABLE>
Yes
Old Jan 19, 2004 | 09:32 PM
ek4ek9's Avatar
Btw what is the b16a2 tranny no,s4c or s80?
i only know they should be hydro
btw one of mate was advised to use the CTR LSD coz it easier because the si and ctr have the 4.4 final drive, in that case is the final drive still be required to be change or whatelse need? pls assist
Old Feb 1, 2004 | 04:11 PM
Spids5's Avatar
Don't judge or question
Default Re: (ek4ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4ek9 &raquo;</TD></TR><TR><TD CLASS="quote">Btw what is the b16a2 tranny no,s4c or s80?
btw one of mate was advised to use the CTR LSD coz it easier because the si and ctr have the 4.4 final drive, in that case is the final drive still be required to be change or whatelse need? pls assist</TD></TR></TABLE>
Yes the jdm final drive is needed for the ctr lsd or you could get the usdm itr or jdm ctr ring gear. Ctr and itr lsd are exactly the same. I have a ctr lsd and jdm itr final drive in my tranny and I love it.
Old Feb 7, 2004 | 03:36 PM
ek4ek9's Avatar
Default Re: (spids5)
thx matey
AMS MIKE
Sep 18, 2006 12:09 PM
emotionisdead
Aug 30, 2005 01:33 PM
bearboy80
28
Sep 9, 2003 09:01 PM
baonest
Aug 28, 2002 07:25 PM
SPOON_BeIgHtEeNsEe
Dec 27, 2001 01:25 PM
