Blown Headgasket? or some mystery problem
Old Oct 17, 2003 | 03:03 PM
91civicEX's Avatar
Default Blown Headgasket? or some mystery problem
i bought an 88 4 door for 300. the car leaked coolant from the water pump area and overheated. i changed the water pump and timing belt and it doesnt over heat or leak coolant anymore. there is another problem. When i try to fill the coolant up and bleed it i get never ending bubles from the radiator. also cylinder #3 isnt firing. it has spark but no fire. i am assuming that the bubles in the radiator are coming from cylinder #3. the oil looks fine, not milky. but the coolant looks like ****. its all rusted and orange. is it possible that the problem is somewhere else? warped head? or is it the head gasket for sure?
Old Oct 17, 2003 | 03:44 PM
Outsane's Avatar
Default Re: Blown Headgasket? or some mystery problem (91civicLX)
very possible you got a warped head or deck..
pull off the #3 spark plug and take a wiff...
Old Oct 17, 2003 | 03:46 PM
91civicEX's Avatar
Default Re: Blown Headgasket? or some mystery problem (Outsane)
what am i smellin for? coolant? the wierd thing is that i dont have any coolant smoke out of the tailpipe
Old Oct 17, 2003 | 03:53 PM
spaceman's Avatar
are you losing coolant?..its gotta be the head gasket,its probably leaking into that cylinder
Old Oct 17, 2003 | 03:57 PM
Outsane's Avatar
Default Re: Blown Headgasket? or some mystery problem (spaceman)
smell for coolant, or water..
if you smell roses I'll be right over
Old Oct 17, 2003 | 04:00 PM
spaceman's Avatar
lol
BigJerm333
12
Aug 5, 2014 08:01 AM
asocallocal
Aug 24, 2009 06:19 PM
A Tribe Called Honda
Feb 21, 2008 03:19 PM
Honda_RN
Nov 5, 2003 08:05 PM
91civicguy
Honda Motorcycles
Nov 29, 2001 10:48 PM
