Smoking need help gsr 1994 grey white smoke
Old Oct 16, 2003 | 04:37 PM
UNDERPAIDMARINE's Avatar
Default Smoking need help gsr 1994 grey white smoke
it only smokes when you first start it up and only when you get on it hardgrey white smoke i just dont understand here is the set , b18c1 1994 with p28 ECU with Skunk 2 Upgraded Chip. Motor: STP Block Saver. Oversized JDM 11-1 compression pistons & Rings. Reconditioned rods; EAGLE Forged 4340 Steel Micropolished & Balanced Racing Crank; UNORTHzoDOX Lightweight Crank Pully; GSR Standard Cam Gears HEADWORK INCLUDES 3 Angle Valve job, Ported & Polished,Bronze Valve Guides; Skunk 2 Valve Springs & Retainers. AEM Cam Gears and Underdrive Pulleys; Cold Air Intake; Skunk 2 Intake Manifold; Full 1 Piece DC Sport 4-2-1 Header; MSD Plug Wires; NGK Plugs; TRANNY INCLUDES ACT Stage 2 Clutch with an 8.0 lb FADANZA FLYWHEEL.
Old Oct 16, 2003 | 05:03 PM
Bull_head360's Avatar
do you have to add oil occassionally? my friend had the same problem but his motor used to boosted and just like any other boosted motor, the valve seals go out...how old is the setup and how long has it been doing this? could be the piston rings too, dunno, jus somethin to check
Old Oct 16, 2003 | 06:14 PM
MEANB18's Avatar
Default Re: (Bull_head360)
haha atleast you don't have the smoking problem I have. My rings are completely fried, when I'm on it, you can't see the back of the car.
2000EM1will
Engine Management and Tuning
Jun 28, 2011 02:40 PM
wishihadaneg
Mar 17, 2008 07:29 AM
FrankensteinCRX
Apr 7, 2004 09:42 AM
UNDERPAIDMARINE
Oct 16, 2003 05:59 PM
UNDERPAIDMARINE
Oct 15, 2003 07:20 PM
