Buying Exedy clutch....same clutch for GS-R and Type R ?????
Old Oct 16, 2003 | 07:58 AM
TypeRuz's Avatar
Default Buying Exedy clutch....same clutch for GS-R and Type R ?????
just making sure.
Old Oct 16, 2003 | 08:02 AM
Asahi's Avatar
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (typeruz)
watch out for installer error.
I'd buy and ACT or OEM personally.
Old Oct 16, 2003 | 08:03 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeruz &raquo;</TD></TR><TR><TD CLASS="quote">just making sure.</TD></TR></TABLE>
I think clutchcityonline had different model numbers for the two..
and don't buy the organic.. it's garbage.. err.. is prone to installer errors..
Old Oct 16, 2003 | 09:09 AM
92TypeR's Avatar
FSAE
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (mstewar)
Yes, the B18C clutches are the same.
I have the organic...for $160 its worth it, plus if it gets F'ed up, its only $160. But its working out for me, no exedy squeeks or anything of the sort. Works fine, feels like the OE clutch, and performs just as well, if not slightly better.
Old Oct 16, 2003 | 09:59 AM
mstewar's Avatar
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the B18C clutches are the same.
I have the organic...for $160 its worth it, plus if it gets F'ed up, its only $160. But its working out for me, no exedy squeeks or anything of the sort. Works fine, feels like the OE clutch, and performs just as well, if not slightly better.</TD></TR></TABLE>
but why not spend a few more $$ and get one that won't potentially have the "installer error" issues of the exedy organic?
Old Oct 16, 2003 | 10:56 AM
B2FiNiTY's Avatar
Which ones should one get to avoid the "installer error"
Old Oct 16, 2003 | 11:19 AM
XR4racer's Avatar
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (B2FiNiTY)
get the Exedy... spend your extra money to have somebody competent do the install.
Talk to P1.
Old Oct 16, 2003 | 11:35 AM
mstewar's Avatar
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (XR4racer)
ouch..
someone competent did mine and treys', thankyouverymuch.. lol..
Cera-metallic &gt; Organic
for the Exedy ITR clutches anyhow.. and the reviews on the cerametallic aren't good either, but because of pedal feel, not part inadequacies..
Old Oct 16, 2003 | 12:03 PM
JiggyKooAndy's Avatar
i just installed the exedy organic 2 weeks ago...i love it so far. can chirp third now...stock clutch didnt catch hard enough to do so before.
Old Oct 16, 2003 | 12:30 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
I just put the ceramettallic in my gsr, with 9.5 excedy flywheel. I can definently tell a difference but it does have the effect of making the whole car shudder (like I read about them) when engaging the clutch. I have driven, and installed the excedy in an ls/vtec car and we havent had any trouble with it yet, but I would prefer the ceramettallic over the organic.
Old Oct 16, 2003 | 03:48 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
but why not spend a few more $$ and get one that won't potentially have the "installer error" issues of the exedy organic?</TD></TR></TABLE>
If people knew how to correctly install a clutch, there wouldn't be any problems in the first place.
Is it Exedy's fault that someone with no mechanical experience screws up a clutch install? I find it hard to believe that one clutch can "create" install errors. There are install errors, and product errors. I've found that after two exedy installs, there is nothing to complain about with the exedy kits.
If I was making more than 200whp, I'd switch to a clutchmasters stage 2. The CM kits are awesome and the pedal feel is very close to OE.
Old Oct 16, 2003 | 05:13 PM
97ITR's Avatar
If I was making more than 200whp, I'd switch to a clutchmasters stage 2. The CM kits are awesome and the pedal feel is very close to OE.</TD></TR></TABLE>
They're being sarcastic. Bunch of people had bad experiences with Exedy. Coles Notes: Exedy blamed install, people blame Exedy. Hence the "install error" reference.
Old Oct 16, 2003 | 06:48 PM
Big Poppa Pump
Guest
Posts: n/a
Where is that fool Mike @ CoxImport.com to blame evryone here that we dont know **** about clutches and all Exedy products are a God blessing to us!!
Mike@CoxImports can go out of buisness for all I care especially after his ridiculos comments and rude remarks made towards this board!! FOOL
Old Oct 16, 2003 | 09:43 PM
mstewar's Avatar
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (97ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ITR &raquo;</TD></TR><TR><TD CLASS="quote">
They're being sarcastic. Bunch of people had bad experiences with Exedy. Coles Notes: Exedy blamed install, people blame Exedy. Hence the "install error" reference.</TD></TR></TABLE>
thank you..
i was pointing out that trey's, smitdog's, and mine were ALL installed by competent mechanics.. sheesh..
Old Oct 16, 2003 | 10:41 PM
Smitdog's Avatar
thank you..
i was pointing out that trey's, smitdog's, and mine were ALL installed by competent mechanics.. sheesh.. </TD></TR></TABLE>
Exedy = Junk...... Very unhappy.
Have the ACT XT-SS now and it holds the power and takes any abuse!!
Old Oct 17, 2003 | 02:35 AM
Maximus's Avatar
Default Re: Buying Exedy clutch....same clutch for GS-R and Type R ????? (Smitdog)
It will work for either application. Exedy makes OEM clutches in japan and have I great experiences with them.
ls_integra
Jul 22, 2008 05:33 PM
devin_hoang
Jul 21, 2008 06:33 AM
b18c eJ1
Feb 26, 2007 06:08 PM
turboD_EG
Feb 8, 2007 09:37 AM
N20civicB18
Jul 23, 2006 10:06 PM
