clutch
Old Jul 20, 2008 | 09:18 PM
ls_integra's Avatar
Default clutch
whats the best clutch to buy for a gsr?
Old Jul 20, 2008 | 09:30 PM
jturbo8316's Avatar
Default Re: clutch (ls_integra)
just buy a clutchmasters stage 1 or 2 thats plenty of clutch either way.
Old Jul 20, 2008 | 09:57 PM
Dark@Powers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_integra &raquo;</TD></TR><TR><TD CLASS="quote">whats the best clutch to buy for a gsr?</TD></TR></TABLE>
You do not need over an OEM clutch if you aren't even putting out above stock numbers...
Old Jul 20, 2008 | 10:13 PM
Rickdrizzle's Avatar
A clutch made out of gold that has 4 plates.
Old Jul 20, 2008 | 10:27 PM
Default Re: clutch (Rickdrizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle &raquo;</TD></TR><TR><TD CLASS="quote">
A clutch made out of gold that has 4 plates.</TD></TR></TABLE>
That's not funny....... seriously dood.
We all know platinum clutches &gt; gold.....
Old Jul 20, 2008 | 10:29 PM
__oversea's Avatar
exedy stage1 or atc stage1 will do just fine on stock.
Old Jul 21, 2008 | 02:21 AM
dohc_profile's Avatar
order from gripforce. i dealt with them, fast delivery and good product. i wouldnt go above stage 1. take it from someone owning a stage 2.
Old Jul 21, 2008 | 02:26 AM
gtec8285's Avatar
Default Re: (dohc_profile)
stick with the stage 1
other stages will be harder to drive as daily driver and more chances for you to brake axles with higher stages clutch
but if you plan on building you motor then get a higher stage to hold horsepower of your motor
Old Jul 21, 2008 | 09:38 AM
Canibuz's Avatar
Default Re: clutch (__oversea)
I just changed to a Exedy stage 1 and im car chirps now in every gear except while shifting into 5th i'd strongly recommend it.
Old Jul 21, 2008 | 01:34 PM
Default Re: clutch (Canibuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canibuz &raquo;</TD></TR><TR><TD CLASS="quote">I just changed to a Exedy stage 1 and im car chirps now in every gear except while shifting into 5th i'd strongly recommend it. </TD></TR></TABLE>
Old Jul 22, 2008 | 07:57 AM
96cgpteg's Avatar
Old Jul 22, 2008 | 08:52 AM
seldon's Avatar
Default Re: clutch (96cgpteg)
i got a f1 racing (something like that) stage 4 clutch from gripforce, basiclaly stock engine for now, building an ls/vtec, but my stage 4 is boss
Old Jul 22, 2008 | 03:45 PM
dumada9's Avatar
Default Re: clutch (seldon)
just ordered a stage 1 exedy clutch and lightweight fidanza flywheel my girlfriends brother has a act stage 1 clutch on his lsvtec ef2 and that **** grabs good. however if you plan on tracking your car and running slicks. launching at 6000 rpms a stage 1 clutch might slip a little
Old Jul 22, 2008 | 05:33 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
depends on what you want to do.
Back in 2003 I spent over $600 on a Clutchmasters Stage 1 and Clutchmasters 7.5 lb. flywheel. It was great, but I probably didn't need a Stage 1, cuz I only drag raced it a couple of times and autocrossed like 3 times on it.
Now I just replaced that with an Exedy OEM clutch for about $130 and new flywheel friction surface from CM for $100 (for a damn piece of steel and hardware ). Engine is all stock so that's all I need.
STEVE-O7
Oct 10, 2007 05:18 PM
turboD_EG
Feb 8, 2007 09:37 AM
ic89
Oct 17, 2006 11:59 AM
getdrugtoday
Dec 17, 2004 04:56 PM
AspectIndustries
Jan 5, 2004 07:49 AM
