Will my battery hold up?
Just picked up a mint 91 Civic sedan, just wondering if the battery will hold up if I power two amps one (small) for mids and the other (medium power range) for subs.
I was told that the car has a low output (super small) alternator and this setup would cause a heavy load and low life on the battery...
Anyone out there have any experience/expertise that they can advise me with?
I noticed dimming on my car when I had a 500w w/o cap. I'd definately suggest getting a 1 farhad cap. they're relatively cheap ($80 bucks or so for a rockford fosgate) and it'll save your alternator from having to work so hard.
I've said it before and I'll say it again cuz it was my project for the month : "Upgrade your factory grounds to 4AWG"!
It helps. I am pushing ~750WRMS and I get barely noticeable dimming at a volume much higher than my ears could ever take.
500W is not much. The alternator should be able to handle it. Whiterabbit on 7thgencivic.com is pushing ~1700WRMS (with D class amps so higher effeciency, but still a lot of wattage) on his stock alternator and a optima red top. No cap. Upgraded grounds and alternator +.
Check out this test by Richard Clark and see if you still feel the same way about caps. http://www.welcometotheden.8k....t.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva »</TD></TR><TR><TD CLASS="quote">Check out this test by Richard Clark and see if you still feel the same way about caps. http://www.welcometotheden.8k....t.pdf </TD></TR></TABLE>
That article is about the 15 Farad caps. That is not a blanket statement about all capacitors. Please re-read. Don't try to read between the lines because they are entirely different lines. If you are exceeding the limits of your alternator a cap will do no good. If you are exceeding your limits of the alternators response time for current changes then a cap will help.
