whats the biggest bore u can get out of a 4 cylinder honda/acura motor?
H blocks can be bored out to 90 mm when sleeved.
I have no idea how much you can bore out a K24.
A 90mm H23vtec is about a 2.4L.
I'm sure you can bore and stroke an H-Series motor to the 2.6-2.8 region.
If you are talking about the new K24 the H-head won't exactly bolt up but other K series heads will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtomloc »</TD></TR><TR><TD CLASS="quote">didn t honda make a 2.4l in the odssey van?
nah it used the 2.2 f22 motor. it was crap.
theres a guy on this board that has a 2.6 liter "h22a", forgot his screenname.
anyone know what 2ponit6 ran on the 1/4 and how much power he dyno?
also how much did the 90mm piston cost him?
whats wise? a stock h23 vtec turbo with 50 shot nitrous or a h23 vtec sleeve and bore 90 mm
yes the K and H motor parts will not bolt up as already mentioned above.
also if forged pistons are going to be used in an H22 or H23, it is highly recommended to resleeve due to the OEM style FMR sleeves which do not work well with forged pistons. and using boost + N2O isn't really a good idea, especially with stock sleeves. why use both when only one will do the job??
the H23 bottom end, or an H22 bottom end with H23 crank/rods, and an H22 head is a good combonation from what i hear. but i have never worked with the H series motors, so i don't have any direct experience. just what i have seen and heard. and yes 90mm is about the max that most will overbore to on the H series sleeved block. i don't know if 91mm is recommended.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_CRX_Si »</TD></TR><TR><TD CLASS="quote">what is the highest recomended bore on RS sleeves on a d-series? I was thinkin of boring out to 87mm is that possible with RS sleeves and a block gaurd?</TD></TR></TABLE>
For a street car Id say 78mm is about the biggest you can safely bore too on a sleeved D block. Ive seen 81mm before but that was for a full drag car and they had gasket problems like crazy.
i'll be taking my LS block to 84mm but thats been done a 1,000 times. i'd also like to see who here went nuts on the boring and how it worked out for them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_CRX_Si »</TD></TR><TR><TD CLASS="quote">well is the B-series block larger than the d-series or somethin???</TD></TR></TABLE>
The bore on a B series engine is bigger than the D series. It makes sense because the B series can rev higher with a bigger bore and a smaller stroke, while the D series has a smaller bore and a larger stroke, thats why the D series motors can't rev as high.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtomloc »</TD></TR><TR><TD CLASS="quote">anyone know what 2ponit6 ran on the 1/4 and how much power he dyno?
whats wise? a stock h23 vtec turbo with 50 shot nitrous or a h23 vtec sleeve and bore 90 mm </TD></TR></TABLE>
2Point6's H22, is now a 2.44. He ran a 13.0@104 with one of his shifter cables snapping at 1000' mark. You have to remember that this motor was in a 2600+ Accord on slicks. The motor put down 247hp and 182 torque
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm420 »</TD></TR><TR><TD CLASS="quote">i'll be taking my LS block to 84mm but thats been done a 1,000 times. i'd also like to see who here went nuts on the boring and how it worked out for them
why not go b20..?? b20 bore is 84mm as well, i want to take my b20 to 85mm with some 12.5:1 compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_CRX_Si »</TD></TR><TR><TD CLASS="quote">But is the block basiclly the same size or what?</TD></TR></TABLE>
Have you looked at the motors before? It's plain to see the B-Series is physically larger then a D-Series motor.
87mm on a D-Series would just be rediculous.
crxracer2
Oct 15, 2004 09:46 PM
