Does the # of bolts on an exhaust flange matter?
Old Oct 15, 2003 | 03:08 PM
speedymon's Avatar
Default Does the # of bolts on an exhaust flange matter?
I ordered some exhaust flanges from accordinglydone.com and got the wrong ones. I ordered (2) 3 bolt flanges and a 3 bolt gasket. Instead i got the 2 bolt flanges and gasket. Can't i just use these or is there a reason the back of the catalytic converter uses a 3 bolt.
Old Oct 15, 2003 | 04:05 PM
kommon_sense's Avatar
Default Re: Does the # of bolts on an exhaust flange matter? (speedymon)
a 2 bolt flange isn't going to line up at all with the 3-bolt. Send them back and get the correct ones.
Old Oct 16, 2003 | 07:45 PM
speedymon's Avatar
Default Re: Does the # of bolts on an exhaust flange matter? (kommon_sense)
No i think there's a misunderstanding. This is a custom exhaust so I'll be welding on all the flanges. Instead of using 2 3bolt flanges I'm going to use 2 2 bolt flanges in it's place. Anything wrong with that?
Old Oct 17, 2003 | 02:04 AM
3-bolt would be better. Also, you must have a 3-bolt flange to connect to the stock cat.
oojoe24oo
Welding / Fabrication
12
Dec 29, 2004 05:16 PM
adseguy
Jul 28, 2004 06:07 AM
xjohnx
20
Sep 10, 2002 01:38 PM
xjohnx
Sep 9, 2002 06:57 PM
