Get used rotors turned or not?
Old Oct 15, 2003 | 02:36 PM
crazy eyez killa
Guest
Posts: n/a
Default Get used rotors turned or not?
Hey
My buddy is parting out a 2000 Si. My brakes went bad after a good autocross session (front rotors are cracked all over). I bought the front rotors off my buddy.
They have some rust on them, much like any other rotor that sits for a month.
Should I get them turned, or bolt them straight on??
Old Oct 15, 2003 | 03:04 PM
VTECorona's Avatar
Default Re: Get used rotors turned or not? (KURRRWA)
Get them turned since they are already off the car.
Old Oct 15, 2003 | 03:16 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: Get used rotors turned or not? (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">Get them turned since they are already off the car.</TD></TR></TABLE>
Aiight.
Old Oct 15, 2003 | 04:28 PM
K20EG's Avatar
if the rotors are cracked ...you dont want to use them
turning the rotors wont make a difference the damage is deeper than you can see
same thing applies to hotspots
Old Oct 15, 2003 | 09:20 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: Get used rotors turned or not? (K20EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">if the rotors are cracked ...you dont want to use them
The ones I have now are cracked. The new ones look good.
Old Oct 16, 2003 | 05:07 AM
K20EG's Avatar
good deal ...then you have your answer
Old Oct 16, 2003 | 07:11 AM
shogunofthedark's Avatar
Definitely get them turned, and I would replace the brake pads while you were at it. If you use your old pads on a set of freshly turned rotors the old pads will score the new rotors and cause the rotors to overheat faster. I have seen a lot of people do this when I was a manager for Auto Zone and they always were back in the store a few weeks later buying NEW rotors AND a new set of pads.
Old Oct 16, 2003 | 08:10 AM
R6Elmo's Avatar
Default Re: Get used rotors turned or not? (shogunofthedark)
turning rotors is about 6 bucks a piece, new rotors are about 20 bucks. So you could just buy new ones hehe
Old Oct 16, 2003 | 08:39 AM
crazy eyez killa
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shogunofthedark &raquo;</TD></TR><TR><TD CLASS="quote">Definitely get them turned, and I would replace the brake pads while you were at it. </TD></TR></TABLE>
Already ahead of the game
Old Oct 16, 2003 | 10:39 AM
Snapshift's Avatar
Like others have said before. Turn your rotors and new pads. Do it right once, or half *** twice.
Old Oct 16, 2003 | 03:16 PM
Roger's Avatar
Default Re: Get used rotors turned or not? (Snapshift)
if your rotors aren't warped ( due to incorrect torque specs for your lug nuts ), then have them turned.
Old Oct 16, 2003 | 05:45 PM
Xazzu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snapshift &raquo;</TD></TR><TR><TD CLASS="quote">Do it right once, or half *** twice. </TD></TR></TABLE>
*I'm with stupid*
Old Oct 16, 2003 | 09:10 PM
Stripped Honda's Avatar
99-0104
Default Re: Get used rotors turned or not? (Roger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Roger &raquo;</TD></TR><TR><TD CLASS="quote">if your rotors aren't warped ( due to incorrect torque specs for your lug nuts ), then have them turned.</TD></TR></TABLE>
this is the stupidest thing i have ever heard .... how is the torque specs going to warp the rotors .. please provide proof from a reliable source before posting nonsence like this .... remember the rotors back is on the hub and the front is on the rim how is the torque going to do anything ???
Old Oct 16, 2003 | 10:09 PM
^jefs0ng's Avatar
Banned
HAha that's quite funny.
Azxster
14
Oct 11, 2007 10:07 PM
chairwitharmrests
Sep 3, 2007 03:40 PM
ACURACY_VTEC
Dec 30, 2006 03:05 PM
petrv
Jan 21, 2005 06:05 AM
eluder33
Nov 15, 2004 09:12 PM
