d15/d16 interchangability ?s
Old Oct 15, 2003 | 06:05 AM
solorexer's Avatar
Default d15/d16 interchangability ?s
Has anyone tried to use a d16a6 crank/rods with d15b2 pistons in a b2 block? Are the main bearings identical between the a6 and b2? Are there any differences that would make this not possible? Thanks to anyone who has this info.
Old Oct 15, 2003 | 08:31 AM
phatrick2332's Avatar
you cannot put a d16 crank into any d15. The main journals are to small in the d15. Yes, you can use the d15b2 pistons in an a6 block though, and it will give u a lil higher compression. Or use d15b7(dx) pistons becuz they have .4 more points higher compression than the SI.
Erickgonz20
Engine Machining & Assembly
Dec 6, 2015 10:25 PM
4door93civic
Jan 3, 2014 12:35 PM
101Importpete1
Jan 13, 2012 02:29 PM
d15bef
Mar 11, 2010 08:49 PM
waterblast02
Dec 5, 2006 10:21 PM
