which ecu for jdm h22
Old Oct 14, 2003 | 11:43 PM
stRodda's Avatar
Default which ecu for jdm h22
what are the differences in the specs of the p28 and p72? and which would be better in what type of app.
Old Oct 14, 2003 | 11:54 PM
puffxy's Avatar
take a look at:
https://honda-tech.com/zerothread?id=567799
basically, with the p28 u lose ur secondary butteryflies (IAB's) and the knock sensor as well. You lose low and mid range power due to loss of the secondaries.. but high end should be same.
with the p72 get both knock and secondaries.. but they cost alot more.
in either case, you'd wanna get them chipped with a h22 program anyways.. i was repeated recommended a p28 chipped with hondata. Unfortunately money has been shy with me lately so i opted for a less expensive approach. I ended up with a p72 chipped with a h22a program i got from someone no PO. runs pretty nicely and i would say i'm satisfied. And if i happen to want hondata in the future, the p72 can be chipped with hondata.. open window!
good luck, hope this helped.
gorthjr
Sep 17, 2012 09:41 AM
deauboy
Nov 2, 2010 02:33 PM
EuRoBrO
Aug 25, 2004 01:53 PM
st0nedstoopid
Nov 5, 2003 03:26 PM
H22ek4
Feb 18, 2003 04:42 AM
