ARP wheel lug studs
Honda-Tech Gold Member
With my new wheels, my 6 sided, hollowed through lug nuts only grip a few threads on my stock studs.
Bought some long ARP wheel lug studs for my 5th Gen and tried to install it a little while ago but got stuck trying to pull off the center staked axle nut.
I pryed the staked part of the nut out and got my 36mm with a Snap On SNH24C breaker bar but just could not break it loose. I just started to spin the axle with my other wheel on the ground and the tranny in gear.
Without having to use an impact gun, is there another way? Or am I just SOL?
I guess I've gotta find time out at work to work on my ride then.
when i took off my axle nuts, i had to have both wheels on the ground someone inside with the brakes on and a 6 foot breaker bar. after that they can off easily
someone on the breaks works sometimes....take a screw driver thats pretty strong and stick it in the top of the roter. inbetween the front and backside of it, when you turn it, it will hit the caliper and stop turning.
first time i removed the spindle nut on the driver side it took a 1" 1250 ft lb impact wrench to break it loose @175 psi. the passenger side took 3/4" 750 ft lbs to break loose @175 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker »</TD></TR><TR><TD CLASS="quote">first time i removed the spindle nut on the driver side it took a 1" 1250 ft lb impact wrench to break it loose @175 psi. the passenger side took 3/4" 750 ft lbs to break loose @175 psi.</TD></TR></TABLE>
holy jeez! who just "happened" to have a huge 1" impact gun layin around?
93grayeg
May 12, 2011 09:37 AM
Toy Civic
Jun 6, 2008 01:06 PM
