OEM cam question
Old Oct 14, 2003 | 07:25 PM
AngelTeg's Avatar
Default OEM cam question
Looked around, did a search, still couldnt find the particular information I was looking for...
I am building a turbocharged CRVtec engine. B16A head, B20 block, you should all know the deal.
now I am building this motor to handle incredibly high boost and Nitrous applications, while still being streetable... based on what I've read over the past few months, I was told that basically, if you want to maintain good streetability to go with ITR cams.
However-
lately, as I've searched a little more, I've been hearing that for turbocharged vehicles, GSR cams are actually favorable over ITR cams.
My main question is this- nobody ever compares Si cams to GSR and ITR cams, so I'm asking someone to do that.
how are OEM B16A cams? and if it matters, my head is a newer style ('97 I believe... off of a del sol) B16A head with a 5 angle valve job, and ITR lifters.
Running high boost (20+ psi for high boost setting... 8 psi on the street) and a nice size Nitrous shot for serious big money racing... what kind of cams should I be looking at? can I use the stock B16 cams? are GSRs a good upgrade (GSRS are cheap... like 100 bucks.)
let me know what you think.
thanks in advance.
-Mike
Old Oct 15, 2003 | 03:00 PM
AngelTeg's Avatar
Default Re: OEM cam question (AngelTeg)
bump to the top...
I'll make the question easier for the less technically inclined.
what's better, SI cams or GSR cams on a boosted motor?
-Mike
Old Oct 15, 2003 | 04:10 PM
junya16's Avatar
go w/ the gsr cams...and also i'm just curious if you're goin to 20psi w/ nitrous on stock sleeves??
Old Oct 15, 2003 | 04:49 PM
AngelTeg's Avatar
I was planning on it, but I'm anxious to hear what you have to say about it... its a little late to be changing plans, as everythings off getting balanced. I didnt think that I'd need sleeves, the machine shop that I deal with alot didnt reccomend sleeves except if I wanted to bore over the motor .
clue me in on what you're thinking.
-Mike
slowteg90
Apr 12, 2007 09:41 AM
sohctodohc
Feb 6, 2007 06:03 PM
Hybrid EK
Jun 15, 2003 09:51 PM
Charlie Moua
Mar 31, 2003 08:30 AM
