Euro R?
What vehicle do I order a MAP sensor from for a Euro R? The integra Type R MAP sensor mounts in the same spot on top of the throttle body and it lists for over $200. The Prelude SH also mounts in the same spot and lists for $48, but I can't tell from the pics of them if either will fit or work.
I swapped an 01 Euro R H22 into a 93 civic. The car runs but the idle bounces between 1000 and 2000 RPM. Last weekend I retraced and rechecked all of the wiring and found that according to my manual I had two wires on the MAP sensor in the wrong spot. I reversed them and started the car and it ran as if the MAP sensor was unplugged and gave a code 3. I put the wires back to their original positions, reset the ECU and it still runs as if the sensor is unplugged. So I am assuming that by following my shitty manual I screwed up the MAP sensor.
Boosted Chemist
Jun 15, 2005 02:30 PM
