Which USDM engine wire harness can i use on a 2000 jdm b16a
Old Oct 14, 2003 | 04:01 PM
Nice_Dc2r's Avatar
Default Which USDM engine wire harness can i use on a 2000 jdm b16a
Which USDM engine wire harness can i use on a 2000 jdm b16a. I would rather use an OEM harness than make one again
Old Oct 19, 2003 | 07:17 PM
jeremy.'s Avatar
Default Re: Which USDM engine wire harness can i use on a 2000 jdm b16a (nice_eg)
the harness that will make you keep your car
Old Oct 22, 2003 | 09:16 PM
RS_H22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg &raquo;</TD></TR><TR><TD CLASS="quote">Which USDM engine wire harness can i use on a 2000 jdm b16a</TD></TR></TABLE>
any obd1 harness will pretty much plug up with the exception of the VTEC solenoid, oil pressure switch... yada yada yada... Its no biggies to add those in, your main/in cabin harness is already wired for VTEC so you can go in and add the additional wires at the plug where the engine harness mates to the cabin harness... thats located on the pass. side by the fuse cage in the engine bay... its always good to ad the new wires with a plug borrowed from an old harness so if you ever need to pull the motor for any reason you can just inplug the new wires instead of cutting them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg &raquo;</TD></TR><TR><TD CLASS="quote">I would rather use an OEM harness than make one again</TD></TR></TABLE>
Make one? Again?
lol, your funny Josh... lol
Modified by RS_H22 at 6:55 AM 10/23/2003
GsDAteg
Jul 17, 2009 06:32 PM
hannslebo
12
Jun 4, 2009 12:24 PM
UGLYEK
Jul 11, 2007 08:52 PM
LostAndFound
May 14, 2004 12:02 PM
