Accord 98 v6
Old Oct 14, 2003 | 12:48 PM
yasir4u's Avatar
Default Accord 98 v6
I have Accord 98 and i had a little race with a guy who owned Accord Lx 1990 he told me this site is really helpful to maintain my car. I bought my Accord like a month ago and i wanna know how to make it as much efficient and powerful as possible ... for example which type of air filter should i use what oil which type of gas and stuff and so on please help me and thanks in advance for eevryone
Old Oct 14, 2003 | 12:55 PM
iam7head's Avatar
Default Re: Accord 98 v6 (yasir4u)
CANT go wrong with oem
Old Oct 20, 2003 | 07:25 PM
yasir4u's Avatar
Default Re: Accord 98 v6 (iam7head)
If i wanna increase the efficieny of my car whats the first thing you suggest?
Old Oct 20, 2003 | 07:29 PM
solo2slocivic's Avatar
exhaust
Old Oct 20, 2003 | 08:22 PM
hondafied's Avatar
Im a mechanic at a honda dealership so take it from me. You left out an important fact about your accord, mileage. Every 90k miles you need to replace the timing belt, and while youre in there its always a good idea to change the w/p and seals. Also check the tranny fluid because honda has had a lot of problems with their auto tranny's. For HP I would recommend just a catback and an intake. the stock exhaust on the v6 accord is designed fairly well to accomodate the flow but the intake on those cars needs help, plus a v6 w/intake just sounds mean. Look into a 50-100 shot of nitrous also, just make sure its a wet kit and use premium gas. good luck.
Old Oct 20, 2003 | 08:27 PM
iam7head's Avatar
Default Re: Accord 98 v6 (hondafied)
one question for the honda man, isnt the all c serie's valves are hyd?
i though my old c27 is mechanical and it's actually hydrauic
Old Oct 20, 2003 | 09:28 PM
potator's Avatar
Search is your best friend.
Old Oct 20, 2003 | 09:58 PM
showgunz's Avatar
Also some OBX headers will give you nice gains at the cost of quality. Unorthodox Racing pulley set will give you nice gains for the price as well. Those two are your low-budget power adders. There's another pulley maker releasing a set but I don't trust their quality.
Old Oct 21, 2003 | 08:48 AM
Elvis1977's Avatar
GOT a good question for ya?
Why does my Honda Accord vibrate at idle slightly especially in the mornings??? Vibration did not occur until my timing belt, balancer belt were replaced. HONDA dealership claim everything is Normal???
Thanks.
Old Oct 21, 2003 | 05:05 PM
mwkirchner's Avatar
Default Re: Accord 98 v6 (Elvis1977)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">GOT a good question for ya?
Thanks.</TD></TR></TABLE>
What year is the Honda you are speaking of?
If it is a 4 cylinder ... it has a balance shaft in the engine and if it is out of time ... you will get the vibration you are speaking of. I only mention this because you say that you did not experience this until you had your timing belt changed. The balancer shaft belt would have been changed at that time also. The Honda garage can take it apart and check all the timing marks to be sure they are correct. All it takes is the belt being off one tooth and it will cause a vibration.
I work for a Honda garage and it bothers me that the garage you took it to would tell you that everything is normal ... unless of course they have taken it apart and checked it.
You can also get some vibration from weak motor mounts.
More information would be helpful from you to be able to help you further.
Old Oct 24, 2003 | 03:37 AM
Gerhard_001's Avatar
Intake is your best bet. The cold air intake will give you as much horsepower as a header and cat back combined. And follow up on maintenece.
Old Oct 28, 2003 | 03:15 AM
yasir4u's Avatar
Thanks a lot people i really appreciate it... I have started some research on my accord engine and stuff .... i dont know what intake means may be i will know it soon .. i m sort of new in this car thingy ... Also i use Premium gas every time ... i change oil mostly at 4000 Kilometres i m looking forward to change my timing belt i dont know how to but i will find out a way but my car is only 105,000 Km .... there is one more question that my car says Maintaince required What does that mean and how to get rid of it ... thanks for all of you out there .. Take it EZ
Old Oct 28, 2003 | 04:59 AM
angelovargas's Avatar
You may also want to check:
http://www.v6performance.net
They have a wealth of information on your 6th gen Av6.
Old Oct 28, 2003 | 11:57 PM
Doom878's Avatar
Premium has been dyno proven to decrease hp on our car. Stick to the cheap stuff.
MyAcc0rd
Mar 1, 2018 01:13 AM
DC2TYPER90
11
Jun 1, 2012 01:55 PM
del_sol_freak
Apr 4, 2011 04:47 AM
marginman
Mar 19, 2006 04:44 AM
Nikos
Aug 8, 2002 08:58 AM
