b16a 84mm
Old Oct 14, 2003 | 12:13 PM
Outkast_CL9's Avatar
Default b16a 84mm
Looking to see what kind of power gains you should see with a b16a sleeved to a bore of 84mm...I know that the 84mm bore will make the motor a 1.7 liter...Will you still be able to rev the motor like a normal b16a.
Opinion Question.
This is going to be going into a 90 CRX. I would you recommend doing something like this or sticking with my orginal plan which was to build a crvtec?
Old Oct 14, 2003 | 12:21 PM
-KangaRod-'s Avatar
It'll be even happier in the high rpm range.
Old Oct 14, 2003 | 03:53 PM
MackSpeed-616's Avatar
Default Re: b16a 84mm (Outkast_EF8)
a waste of money to sleeve a b16 when all you have to do is buy a b18c for the same $ and have factory reliability
Old Oct 14, 2003 | 03:58 PM
Default Re: b16a 84mm (MackSpeed-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">a waste of money to sleeve a b16 when all you have to do is buy a b18c for the same $ and have factory reliability</TD></TR></TABLE>
yeah but I thought the b16a would be better because of the near perfect rod ratio...
Old Oct 14, 2003 | 10:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast_EF8 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah but I thought the b16a would be better because of the near perfect rod ratio...</TD></TR></TABLE>
no. this has been covered a million times.
xtokex
Oct 6, 2007 05:05 AM
gunnerman
Feb 16, 2007 12:03 PM
buffgsr
18
Nov 16, 2006 06:34 PM
fiji_crx
14
Jun 19, 2006 12:38 PM
Two_K Si
13
Apr 17, 2004 05:51 PM
