How do I get to the tenioner?
Old Oct 14, 2003 | 11:55 AM
NX_LS's Avatar
Default How do I get to the tenioner?
I really need to get my timing belt back on, like, yesterday.
I just put the stock cams back in my car, but now I can't get the timing belt onto the cam gears. I need to reach the tensioner. I know it's just above the crank pulley, but with the timing cover still on, and all of the accessories still in place, it seems impossible to get to. How do I get the 14mm socket up there to loosen the tensioner? Do I need to move my A/C pump or what?
Old Oct 14, 2003 | 01:20 PM
skribblah's Avatar
Default Re: How do I get to the tenioner? (NX_LS)
start to dissasemble accessories stephoney
Old Oct 14, 2003 | 02:09 PM
EP3_05's Avatar
On my 1g b16a there is a plug on the timing cover that can be removed to allow access to the belt tensioner. It is a rubber plug about halfway down towards the crank pulley.
Old Oct 14, 2003 | 02:49 PM
sleepyEK's Avatar
Default Re: How do I get to the tenioner? (91civic)
i have one question for you, did you at any moment have the tension loose on the back side, cause if you did, i highly recommend that you spend the five minutes and take the lower timing cover off and make sure everything is lined up. just a little advice from an acura tech. oh btw, be careful with that tensioner bolt, the sides are very shallow and is easy to strip if you don't use a GOOD 6 point socket. don't use a 12 point.
pmgriphone
19
Sep 4, 2015 08:11 PM
4dr_Noob
Nov 2, 2011 09:02 AM
teddy_dc2
Jul 6, 2006 09:15 AM
LSEGHATCH
30
Aug 18, 2005 07:32 AM
lunchboxEF91
Nov 17, 2004 09:00 PM
