can you rechip an odb-0 ls ecu to run vtec
Old Oct 13, 2003 | 10:55 PM
0554's Avatar
Default can you rechip an odb-0 ls ecu to run vtec
basically what i am askin is can i rechip a non vtec ecu to kick vtec on.
Old Oct 13, 2003 | 11:06 PM
XDEep's Avatar
Default Re: can you rechip an odb-0 ls ecu to run vtec (88crex)
one method is to keep your pr4 base and insert the maps, then use an external trigger, like an msd rpm activated switch. there is also code that has been inserted to trigger vtec via one wire w/o the use of an external trigger, but i believe its pm6 based which should be ok to use. check here for details http://pgmfi.org/phorum/list.p...8&a=2
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
re_X_si
Oct 30, 2007 10:14 PM
Dc2 Joe
May 23, 2007 04:35 PM
Addicted2Racing
10
Jan 27, 2004 04:29 PM
davken1102
Aug 2, 2003 06:01 PM
