B16 w/toda stroker or b18c1 swap?
Old Oct 13, 2003 | 08:40 PM
HUBB's Avatar
Default B16 w/toda stroker or b18c1 swap?
what will better to swap into my 93 EG. which would pull harder and be best for the $$$. thanx
Old Oct 13, 2003 | 08:41 PM
nwdave's Avatar
Default Re: B16 w/toda stroker or b18c1 swap? (HUBB)
I haven't seen numbers from a stroked B16, but I imagine that the cost:performance ratio would be much better with a B18C1.
T4eg's Avatar
i would go with the B18C1. Its cheaper and a better starting point IMO
Old Oct 13, 2003 | 08:45 PM
HUBB's Avatar
Default Re: B16 w/toda stroker or b18c1 swap? (BlueHatch00)
thanx ....i know my question is quite vague but i am planning on getting a swap soon and i need advice..thanx
Old Oct 13, 2003 | 10:17 PM
gamakichi77's Avatar
you should go for CROWER if your'e serious racer. u can go for 87mm bore and 96mm stroke for your B16A blocks. But you can use for race only. get a spare engine for daily use. But do remember, get your block for sleevings for your safety.
If you want more cheaper, get B18C5. this is more efficient rather than B18C1. if here, we can buy this B18C5 ( B18C R, my country code ) for only US520.00 only.
dgblake2008
Aug 10, 2006 06:46 PM
JDMroyEG5turbo
Mar 16, 2006 11:43 PM
DOHCRX
Aug 5, 2003 05:46 PM
lsintegra11
Oct 15, 2002 04:36 PM
BuRcH
36
Oct 13, 2002 06:18 PM
